flywheel nut
/ flywheel nut #1
hogger75
yanmar 2210
has anyone ever removed the big nut holding the flywheel on a yanmar 2210 ?also what size socket did you use? how do you getit torqued back down etc.?am at an impasse here crank needs to come out to be turned any help would be appreciated thanks
/ flywheel nut #2
Measure the nut and get the correct socket, then if no BIG impact wrench, use a breaker bar, with extension pipe if necessary, placed near the ground, or bumper. Bump the starter, the engine will turn clockwise and loosen the nut.
/ flywheel nut
starter not in picture as engine is out and on ground nut is hard to measure as it is in a recess in flywheel best i can measure is 2 5/32" just trying to find out what others have used or done as IT manual says this nut is to torque to 275-304 ftlb how did you hold the flywheel for that
/ flywheel nut #4
That's going to be a major problem without a BIG impact wrench. It's probably on there at 500+ ft. lbs.
/ flywheel nut #5
Sometimes there comes a time when you call the roving mechanic, the guy with a huge service truck who can overhaul anything right in your driveway. This is real expensive. He'll have it unscrewed in no time. Or Plan B might be to rent a huge impact wrench and towable compressor.
Can you get the crankshaft out without removing its flywheel? If so let the machine shop remove it or maybe just leave it on while the crank is reground.
Metal Peacock Lawn Art Statue (A66738)
Metal Peacock Lawn...
2016 JOHN DEERE 331G SKID STEER (A65056)
2016 JOHN DEERE...
2018 Ram 1500 Reefer Meal Delivery Truck (A64556)
2018 Ram 1500...
2003 Ford F-350 4x4 Crew Cab Flatbed Truck (A66736)
2003 Ford F-350...
72'' snowblower make?
PORTA POTTY (A68842)
