Fluid in tires
/ Fluid in tires
this kind of post does not even warrant a response. it started as a red herring .
(click) (click) (click) ahhhh.. much better...
soundguy
If this post was so bad why did you jump in with both feet?
All i wanted was some input as i like the idea of fluid in the tires. After retiring and selling my company that had 4 Engineers employed all i wanted was some input from people with experience. Most engineers look at technical issues, this answer i feel was best answered by experience rather than tech,
I think you should take a good look at yourself and stop being so uptight.
/ Fluid in tires #42
Heck yeah...we all know Rim Guard is beet juice! Been around for years...
May be you did but you sure can't speak for all the others:laughing::laughing::laughing::laughing:
/ Fluid in tires #43
that response was not to you, and was not about the original post. it was directed to another individual, and their previous post / reply to my post. I specifically posted that users message so there would be no confusion as to who I was responding to...
I'm not uptight... I simply have some experience with ground and water contamination and mitigation....
soundguy
/ Fluid in tires #44
Rim Guard seems to me to be cost effective from what I have checked on. I had called a dealer last week and they said it would take about 110 gallons for a pair of17.5L-24R4 tires. Total cost would be $330. It would give me about 1200# (11# per gallon) total ballast. That is about .27 a pound. I know it is not readily availible everywhere.
I know I dislike calcium for sure. You have to have a tube. It eats rims and nothing worse than getting a cut tire in the field and having a dead spot. Also it seems when you cut a tire before you can get the cut on top it sprays the tractor.:mad:
Around these parts it is either iron weights or calcium. Rim Guard is catching on though.
I have been around farm tractors all of my life had not heard of using anti freeze or window washing fluid. I thought it was an intersting idea though, but does have some draw backs as well.
Window washing fluid at $1.20 a gallon and weighing around 8# a gallon will come in at roughly .15 a lb. You may have to buy a pump and a valve for your value stem. I haven't priced either one of those items.
50/50 mixed antifreeze would be around .37 a pound. Now if you save your drained anti freeze or buy a used barrel of antifreeze from a car salvage yard you can get that down pretty cheap.
Rim Guard is very competitive when you compare it by weight rather than by gallon and if availible in your area the dealer fills it for you.:)
/ Fluid in tires #45
drill pump is 3.99$ at harbor freight and a burp valve from napa or tsc is likely 5-7$...
not bad to load your own....
soundguy
/ Fluid in tires #46
Checking on some local tire fills, Les Schwab has some stuff they call "BIO-TIRE BALLAST"
Going to the BIO-TIRE BALLAST web site claims all natural and a weight of 9.5# per gal. They never actually say what it is.
Does this sound like Rim Guard / beet juice ?
Here's there MSDS on the stuff.
http://www.bio-tire.com/media/MSDS.pdf
/ Fluid in tires #48
rimguard weighs 10.7-11 lbs. per gallon
soundguy
/ Fluid in tires #49
Hi Folks: When I filled the R4 tires on my JD4300 I used a home made Calcium/Magnesium Chloride mix. I had read directions on line that said to add the salt to the water and stir until it dissolved. Well I stirred and I stirred and I finally decided that I wouldn't live long enough to dissolve enough mix to fill my tires. I have a 2 gal. commercial blender that I had never used. I picked it up a the scrap yard for 15 cents a pound. I used the blender to mix the salt one gallon at a time. I added the calcium/magnesium Chloride until the water would not take any more. Then gravity fed it into the tubeless tires with a 6 gal bucket fitted with a hose bib ( I bought an adapter at Tractor Supply). I had removed the wheels and propped them on a tilt so that I could get enough fluid into them to insure that the rims were covered at the top. I kept track of the gallons of water and the bags of salt and it totaled up to just over 700lbs. The tires have been filled for more than 6 years with no problems. The tractor has a lot more pulling power and is much more stable on the hills and when I am using the loader. I didn't write down the total cost but I think that it was about $75. and the salt mix is much heavier than antifreeze would have been.
Mars
/ Fluid in tires #50
for sure heavier than AF mix.. cacl mix is about 11.5 lbs./gallon
soundguy
/ Fluid in tires
Sorry Sound Guy read it wrong.
/ Fluid in tires #52
Make sure and leave an air cushion space in the tire. The accepted practice is to fill to just over the top of the rim. In my Kubota owners manual it says not to fill the front tires. I gather from reading itis because of the shock absorbing effect of the air only filled tire.
/ Fluid in tires #55
That is exactly the amount I had put in mine and that was the exact price I paid. He jacked it up on my trailer pumped it in and I was good to go. Used 2 55 gallon barrels of the stuff. Only took about 20 minutes for both tires. Did you bring your tractor over here or something??
/ Fluid in tires #56
Good to know I got a good quote.:D I called Rim Guard and got a list of local dealers. I picked the closest and gave them a call. He quoted the price and the amount I would need over the phone. Sounds the easiest way to go and pretty cost effective way of adding ballest. I was thinking wheel weights as I didn't like calcium as an option. Rim Guard sounds better than weights.
It may be a few weeks before I get hauled in. I wish I would of done it before winter.
/ Fluid in tires #57
You will nitice the difference immediately as you raise a full loader bucket. Also doing any loader work a little off camber on an incline it won't feel as tipsy...Good luck and let us know the difference it makes...
/ Fluid in tires #58
Six pages on loaded tires and not a single mention of foam? I realize that foam is not "fluid", but it is heavier than Rim Gaurd for calc. and it won't leak ever.
/ Fluid in tires #59
I just did this.....one tire was full of water, the other only air. Since I plan on taking the tractor to Va. I didn't want just water. I bought the filler valve at NAPA ($12.00 inflation, I guess). Then took the tractor in to a tractor service center (not a dealer) to get the wheels reversed and the mounting plate changed to widen the stance. While there the mechanic asked if I wanted him to fill the tires with the WW fluid that I had bought. I thought about it and said "why not..... " I offered my little adapter....he laughed....jacked up the rear of the tractor so both wheels were in the air and got a large funnel. He attached a fuel line hose to the funnel and the valve stem (after removing the valve). He rotated the tire to stem at top. Every quart or so he would rotate the tire about 8 inches back and forth and the tire would burp. took about 4 minutes per gallon. He did one side, I did the other. We filled it up to the 10 o' clock position which took 15 gallons per tire on my tractor. Then aired it to 20 PSI. Seems much more stable now with wider stance and EQUALLY weighted tires.
Many thanks to the guys here who told ME how to do this..... Rob:thumbsup:
/ Fluid in tires #60
Post some information on it so we can see what it is all about?
LAWSON AERATOR (A63291)
LAWSON AERATOR...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
