Floating The Loader
/ Floating The Loader #11
Brake steering? On a Kubota? Hehehahahoho! What Kubota?
This has been discussed numerous times over the last couple of years. At least on a Kubota with Hydrostat, there aint no way you'll use steering brakes. Tose brake pedals are about inpossible to use in conjunction with the HST pedal.
You guys with the GST and gear tranny's have one up on us folks with HST on that one.
I have tried a number of times on my B8200HST to run the "steering" brakes. It just aint made to do it.
A roll-over scraper, in the reverse position, is excellent for fo smoothing while pulling forward...
RobertN in Shingle Springs Calif
/ Floating The Loader #12
RobertN, you can brake steer a 2910.
It has a cruise control handle that can vary the HST forward travel speed. Thus you can control travel speed with your right hand while you manipulate the split brakes with your right foot. None of the rest of the B series has this kind of cruise. I don't know what the Grand L's have.
Glenn
/ Floating The Loader #13
Funny you mention that with the reversed rollover scraper, I use a rear box scraper with the cutting edge removed so I can actually make use of the rearward facing leveling blade on the BX
/ Floating The Loader #14
That was one of the neatest things about these two Kubota's, somehow the valve on my Ford never had the feature that would allow it to STAY IN FLOAT! It never donned on me that this was possible. When I started using the floats in the Kubotas WOW IT STAYS!!! Why is this important you ask? Going backwards, which means looking backwards at least now and then/w3tcompact/icons/smile.gif is just a little bit easier when your arm doesn't have to be reaching forward while you are trying to look backwards!
And ditto to the comments on putting weight in the bucket, depending on what you're doing that can really help the job, especially when you are doing the final "squishing!"
del
/ Floating The Loader #15
Now you got my interest going. I was wondering what the extra position was for on the loader controls, it sounds like it is float. Have to try it tomorrow.
This board is a great place to pickup all sorts of good info...
DaveV
/ Floating The Loader #16
Hi Del, could you give us more info on the author "Ober" that wrote the book you mentioned on 9/29??
Looked in a number of places with no luck for this author.
thanks again,
george
/ Floating The Loader #18
And if looking for a used book try "abe.com" or bookfinder.com abe stands for Advanced Book Exchange, it is a search engine that searches other book list services. A huge chunk of the used book stores put their lists, or are starting to put their lists of books into these search engines. I've bought quite a few books this way.
Gary J Ober
Operating Techniques for the Tractor Loader Backhoe
Ober Publishing
Northridge California 91324
9514 Reseda Blvd #478
this address is from 1983
I'm always amazed that more dealers don't have these ready for purchase.
/ Floating The Loader #19
RobertN - In addition to Glenmac's comments, you can also brake-steer when going backwards (which is what we're mainly talking about in this thread), by using the toe of your left foot to depress the HST pedal, and your right foot to brake.
MarkC
/ Floating The Loader #20
I like to do final smoothing on soft dirt by floating my 3pt grader blade in the back position.
CFG Industrial MH12RX (A60463)
CFG Industrial...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A61567)
2001 Kubota L3300F...
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
