Floating The Loader
/ Floating The Loader #21
I also tend to do the final smoothing with the scraper blade. I think I like the greater width of the scraper and the ability to set the blade to the same angle as a road crown with the hitch leveler.
I may also get better compacting than with the loader. With the hydraulic top-link, the box can be pointed almost straight down so it rides on the back of the rear cutter. I put the leveled box on the ground with the 3ph and then lengthen the top-link. I think I get some down pressure that way. And, with the smaller area of the blade compared to a bucket bottom, I may get greater compacting as well. Things may work differently with a tractor heavier than my Ford 1710.
Anyway, if I do it with the scraper, then I'm going forward, and I still have good steering. Anyway both ways work, and I do some of each. I've thought about it, and I really don't know why I use the loader some places and the scraper others.
/ Floating The Loader #22
Brake steering on my Ford 1710, with gears, isn't completely sliced bread. The brakes are on the same side as the foot throttle. I tend to set the hand throttle just high enough to give decent loader speeds and bring myself up to operating speed with the foot throttle.
So, there I am tooting backwards down the road with little steering. Every time I start going off the road and take my foot off the throttle to use the brakes, my toot goes to zip. I think that's a similar problem with the HST.
Still, I think using the foot throttle to maintain speed is safer than setting the hand throttle-especially driving backwards. One advantage of my gears is that I have four reverse speeds. So, the toot can be pretty fast. It's probably safer if the tractor slows down just by taking my foot off the throttle. If I had to cut speed by hitting the hand throttle, I get a picture of myself sort of like a punch press operator on speed--all arm waving and foot stomping.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
