4WD and loader work
/ 4WD and loader work #91
As has been said MANY times in the Past. Do NOT use 4x4 unless you NEED it. This also applies to ATV's. END.
/ 4WD and loader work #92
None of my 4WD tractors have ever been out of 4WD except for when roading on pavement.
Never had a problem and no more wear on front tires than the rears get.
I get a kick out of how some people think. A long time ago I worked for a guy and we did snow removal in the winter. I had to plow very large commercial parking lots with a 310 Deere backhoe with only a bucket. (Talk about hating life)
Anyway he always used to get mad at me any time he found it in 4WD or found out I used the steering brakes.🤪 Said I was going to wear it out, LOL
So I just ignored him and carried on, because I liked to be able to steer on the ice and get work done.
I also laugh at all the people that won't use 4WD in their pickup truck in the winter because it will use more gas. But they will sit at the traffic lights spinning their tires and revving to get going on the snow and ice.😂🤣
/ 4WD and loader work #93
There are always special conditions and they can cloud the issue. The answer to the question about when to use 4 wheel drive is pretty straight forward.
Use it when you need it.
When working in conditions where extra traction is required, kick it in.
When lifting relatively heavy weight with the loader because it adds stability and improves control.
When traveling downhill, as mentioned in earlier post. Even with only moderate weight in the bucket it improves control.
When pulling a load having some weight.
Use it when it makes sense.
What not to do.
Turn tight corners with 4 wheel engauged unless it's necassary. Tight corners places high stress on the gears and other components which is intensified when driving on a hard surface including dirt.
A comment about hard surfaces. For the most part ( as I mentioned there are always special conditions ) a tractor does not know the difference between a hard or soft surface and driving in 4 wheel drive on a hard surface will not ruin anything as long as the direction remains reasonably straight. Example: Clearing snow from a driveway with a plow or snowblower. Yeah.. I know a film of snow remains to "grease" the pavement, however it may help it doesn't matter. Just no tight turns.
/ 4WD and loader work #94
your going to learn people have no idea what they are talking about, gear grinding is clear as can be, do you hear it? prolly not, its generally a open differential, there is a reason they have lockers. if your not hearing noise, your not doing damage. i use 4x4 constantly and was slipping non stop today dealing with a flood.
do you know how much my wheels slip while plowing?
Exactly, you bought 4WD, use it. There should be No Grinding, just Wheel Slip.
Wheel Slip is a fact of life, turning a 4WD the front Axle can travel near twice the distance as the Rear Axle, there is Slip there regardless.
/ 4WD and loader work #95
If you don't need 4WD, why use it? I view it as either a necessary evil or a useful tool, to be used only when circumstances dictate. On those occasions, I'm glad its there to either get me out of trouble or prevent trouble. But like the crescent wrench in the toolbox, I'd be just as happy not having to use it.
FWIW, all of my 4WD tractors seem quicker and more responsive in 2WD. They accelerate quicker and turn much better. The whole operation seems much more relaxed in 2WD. If I get on a tractor and it seems sluggish, the first thing I check is whether someone left it in 4WD. To date, that has always been the case.
/ 4WD and loader work #96
That's not how it works. The slip is deliberate, not "regardless". Put on your thinking cap. The internal gearing is different for the front axle and back axles.
The front to rear ratio can be made to be any ratio wanted. It could be zero slip.
A couple of percent mismatch is designed there deliberately. It is a consequence of making the front axle turn slightly faster to maintain steering control.
Think about it.
rScotty
/ 4WD and loader work #97
We've been over this too many times. Please figure out how the system works before spreading misinformation. The mismatch that leads to windup or slip is deliberate. It is there for steering control. It is necessary because there is nocenter differential between front and rear axles on a tractor - or on old part time 4wd pickups. It has nothing at all to do with turning or driving straight. It has a lot to do with traction.
Sometimes - not always - it has to do with reliability.
rScotty
/ 4WD and loader work #98
Ever make a turn in Snow or Loose Dirt? Why are the 4 Arcs and not 2?
Ever turn your F150 on a Boat ramp in 4x4 and have it hop? That is because the Front Axle is traveling farther than the Rear Axle.
Any "Max Force Conditions" (something's Break Point) would be limited to the tire slip.
We are arguing the Same Thing, you are just hearing it different. Yes there is No Center Clutch or Differential, so both axles are trying to go the same distances, (give or take your Steering equations) The Tractor's Max Capacity, would account for Driveline Stresses, (or should be) being in a Dirt Pile even reduces Traction Abilities of the tires.
/ 4WD and loader work #99
While all the experts chime in so will I. I worked at a dealer and found the following in formation.
1. The front wheels on a tractor are geared slightly faster than the rear. It was explained to me you want the front slightly faster so as not to cause the rear wheels to push the front wheels. The front wheels are supposed to pull not ****** the back wheels. This makes the drive parts of the front axle load up and adds a lot of stress when on hard dry surfaces.
2 Loader work. If you are depending on the front axle to drive the tractor with a bucket full and very little tractive force from the back wheels you risk overloading the front axle drive components and risk breakage. The front axle is to assist not take the whole load.
3 But, But. I leave mine in 4wd all the time and never take it out, or I only use 4wd when it rains or snows. Yep heard all these stories as I was repairing the front axle. The choice is yours. It is your money invested in the tractor, and you that will pay needed repairs if any. So use common sense wisely.
/ 4WD and loader work #100
rScotty
Alright now Scotty -- I have no idea who you are saying is spreading 'misinformation' (don't care; can't be me because I haven't expounded on it yet ) but let's not label misinformation while spreading some of it. Most of us reading this needlessly long dialog understand and know that tractors with MFWD are designed and built with intentional slightly faster forward motion in front than rear for all the reasons described ad nauseum. But turns left or right do generate differing distance traveled by the two front tires so there ARE both kinds of slippage. It does have to do with turning versus driving straight as well as the designed-in other reason. And if you happen to be on high traction surfaces like pavement you will feel the jerkiness of tires slipping on the pavement. Not all windup or slip is deliberate, there is also some of it inherent and unavoidable.
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
200 Gallon Tank (A57148)
200 Gallon Tank...
2017 Dodge Grand Caravan Van (A59231)
2017 Dodge Grand...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2018 HINO SA (A58214)
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
