Floating The Loader
/ Floating The Loader #21
I also tend to do the final smoothing with the scraper blade. I think I like the greater width of the scraper and the ability to set the blade to the same angle as a road crown with the hitch leveler.
I may also get better compacting than with the loader. With the hydraulic top-link, the box can be pointed almost straight down so it rides on the back of the rear cutter. I put the leveled box on the ground with the 3ph and then lengthen the top-link. I think I get some down pressure that way. And, with the smaller area of the blade compared to a bucket bottom, I may get greater compacting as well. Things may work differently with a tractor heavier than my Ford 1710.
Anyway, if I do it with the scraper, then I'm going forward, and I still have good steering. Anyway both ways work, and I do some of each. I've thought about it, and I really don't know why I use the loader some places and the scraper others.
/ Floating The Loader #22
Brake steering on my Ford 1710, with gears, isn't completely sliced bread. The brakes are on the same side as the foot throttle. I tend to set the hand throttle just high enough to give decent loader speeds and bring myself up to operating speed with the foot throttle.
So, there I am tooting backwards down the road with little steering. Every time I start going off the road and take my foot off the throttle to use the brakes, my toot goes to zip. I think that's a similar problem with the HST.
Still, I think using the foot throttle to maintain speed is safer than setting the hand throttle-especially driving backwards. One advantage of my gears is that I have four reverse speeds. So, the toot can be pretty fast. It's probably safer if the tractor slows down just by taking my foot off the throttle. If I had to cut speed by hitting the hand throttle, I get a picture of myself sort of like a punch press operator on speed--all arm waving and foot stomping.
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
Bucket (A64194)
Bucket (A64194)
2006 Kenworth T800 Tandem Dump Truck, VIN # 1NKDLU0X26J147788 (A65563)
2006 Kenworth T800...
Brady 512 Feed Wagon (A66408)
Brady 512 Feed...
2015 PETERBILT 579 (A65643)
2015 PETERBILT 579...
Gas-powered Electric Start Air Compressor (A66408)
Gas-powered...
