Float Switch 3430
   / Float Switch 3430 #1
Diamond P
Wilmington DE.
Kubota 3430
Bought a 2003 Kubota 3430 and i'm looking for the float switch for the fel. Not sure if even has one?? Thanks
   / Float Switch 3430 #2
Move the fel control firmly to the right like you u we're going to dump the bucket.
   / Float Switch 3430 #3
I've never seen float on the dump circuit, pretty sure Sandy is wrong. Float, if it's there, is always on the lift circuit. Push the stick all the way forward & there should be a detent there for float. Assuming the 30 series is like every other Kubota I've ever driven.
   / Float Switch 3430 #4
I had a 5030 and the float is the same as 5740, forward past the detent.
   / Float Switch 3430 #5
Sorry about that. You're right I should have said push forward beyond the detent. I guess I need a nap!
   / Float Switch 3430
Thanks, I'll try pushing the stick all the way forward.
   / Float Switch 3430 #7
I had a 2004 L3430HST and the joystick float position is all the way forward past the detent as Fallon suggests. No float on the dump.
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
