Flat, first one...........yuck!
/ Flat, first one...........yuck! #1
DannyD
Indiana
BX 23
Ok, here goes first flat on the bota, and I took some photos.
here it is flat on the bottom, well almost anyway
why do cars not have these built in jacks. and before someone mentions it, no I would not get UNDER the tractor on these, that is what a bottle jack is for, right?
These things were too tight even for my air wrench..........now I have to take it on the trailer.........................NOT
So out to the wash area and some soapy water to find the leak. At least the tire is clean now!
At last, so far this is the only leak I can find. Now if I can find one of those valve stem wrenches.............NO luck, small screwdriver and tighten it that way............so far so good.
/ Flat, first one...........yuck! #6
</font><font color="blue" class="small">( why do cars not have these built in jacks. )</font>
They do your just not looking at the right cars or trucks. Plenty of race vehicles on and off road do /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif
/ Flat, first one...........yuck! #7
Danny,
A good auto store that sells tire repair tools, or a bicycle shop. I have a couple that came with a Camel patch kit. What I use is a valve stem cap with the split at the top.Those caps were on old english racer bikes.I put one on all my sets of wheels.Anything that has air tires around here has one of those split tip caps.
/ Flat, first one...........yuck! #8
After finding out how much my loaded tires weigh, I hope I never see one. /forums/images/graemlins/blush.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif Thought about unloading the tire ballast some weeks back but now I think I'm going to keep them loaded. Guess I'd have to call someone in or turn that leak down and let the load out. Man, they aren't even fun on a Honda Civic. I do like that jack though. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Must have been it, tire is still up and holding
/ Flat, first one...........yuck! #10
Man, that BX23 is clean! Got any scratches in the FEL or BH bucket yet /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
Volfandt
/ Flat, first one...........yuck! #11
Danny...... if you are going to use the impact wrench, it is better to leave the weight on the tire first to loosen them. That way, the impacts are directed at the bolt heads and none is absorbed by the wheel. I have found this to be true many times when trying to get wheels off. I suggest that you consider removing the lug bolts one at a time and painting them with never seize and reinstalling and setting them with a manual torque wrench. My bet is the dealer put them on with a impact wrench with 150 PSI setting. If your impact gun won't touch them, then it is time to break out the 4 way tire wrench and the 2" x 5' iron pipe. Never force it.... get better leverage... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Flat, first one...........yuck! #12
That's some good advice in regards to the tire position Junkman. Plus, I think that it is safer when breaking the lugs free. Gerard
/ Flat, first one...........yuck! #13
Many times you will need to break out the braker bar, and "cheeter" pipe. You will almost always be able to put more forse on a breaker bar, then an impact will have.
Thanks Junkman for the advice.
The tractor will go to the dealer for service at 100 hours this fall, so when there I will have him break them loose and put them back no so tight. Someone mentioned never seize, and since my dealer is so good to me, maybe that and a manual torque wrench will be available.
Yes I have scratches in the bucket and the bh, and yes it is clean. I try to keep it that way when not in use. Keeping it clean makes for a good impression with the neighbors. And, since I will be cutting more than one yard this year, and I like it that way. My next door neighbor this year will be paying if it gets done. Not that I am a hard a## but I have seen to many 24 can cases of beer in her garbage cans, and I am like well if you can pay for that you can pay for the cutting of your yard. I am thinking 20.00 week, for cutting 1/2 acre, no trimming, no clean up (her son can do that if he is not in jail)
Is this fair for the amount of yard?
but wont that scratch the bolt heads, then I will have to get new ones................hhehehehehehheheheheheh
I thought of that, then I thought of just pulling it out and using the old dish soap and hot water on the tire and not even taking it off the machine. Turns out to be a good idea, my one per year according to the wifey!
I have often wondered why they do not build these into cars. Seems like a cool add on, and when you have cars that have 8 cup holders, what else can you do?
Is it a safety issue, since we all know not to get under a car on a jack. I have seen some race cars that pull into the pits and in a second they are up on stands that come down from the car.
/ Flat, first one...........yuck! #17
You should see it when a desert race trruck has a flat and pulls off the course and the driver hits the pnumatic valve and lifts one side of the truck. Where talking trucks with 30"+ front and close to 40" rear travel. I have only seen trucks using two cylinders, there are probably some using 4. The cylinders are on the center balance of the truck (side to side). Of course this is IF they stop to change the tire. Theses guys can change a tire faster than I can figure out which one went flat. /forums/images/graemlins/grin.gif
/ Flat, first one...........yuck! #18
</font><font color="blue" class="small">( I need to move to a <font color="red">RED</font> state! )</font>
If you presently live in a <font color="blue">BLUE </font> state, and move to a <font color="red">RED </font> state, will that mean that you will then be <font color="purple">PURPLE </font>??????? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Flat, first one...........yuck! #19
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I need to move to a <font color="red">RED</font> state! )</font>
If you presently live in a <font color="blue">BLUE </font> state, and move to a <font color="red">RED </font> state, will that mean that you will then be <font color="purple">PURPLE </font>??????? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif )</font>
LOL /forums/images/graemlins/crazy.gif Well I am 37 and single so ya purple sounds bought right /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Junk you had me rolln on that. Still laughing /forums/images/graemlins/smirk.gif
2023 John Deere Z960M Zero Turn (A63116)
2023 John Deere...
BUNDLE OF APRROX (35) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
UNUSED WOLVERINE QMP1-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63118)
2022 Greenworks...
New/Unused 2 Post Car Lift (A61165)
New/Unused 2 Post...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
