Flail Mowers
   / Flail Mowers #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Flail Mowers
What is a flail mower used for??? What does it do that is special? I have been looking into putting in some prairie and everything I read indicates that a flail mower is the best way to cut prairie. But I have no idea why this is so? Apparently it cuts things into very fine mulch which decomposes very quickly. Am I even close?
Anyone care to enlighten me?
Bob
   / Flail Mowers
Flail Mowers
Bob
   / Flail Mowers #3
Bob, I've never used a flail mower and the only time I've seen them used was guys mowing along major highway rights-of-way. So I can only tell you what I've heard and read. They are also sometimes called "orchard mowers"; supposedly "mulch" the stuff much better, as you said. And the other plus is that they're far less likely to launch a rock or other projectile than a rotary cutter.
   / Flail Mowers #4
   / Flail Mowers
</font><font color="blue" class="small">( Bob, I've never used a flail mower and the only time I've seen them used was guys mowing along major highway rights-of-way. So I can only tell you what I've heard and read. They are also sometimes called "orchard mowers"; supposedly "mulch" the stuff much better, as you said. And the other plus is that they're far less likely to launch a rock or other projectile than a rotary cutter. )</font>
Thanks. Every answer leads to another question. So why not use a flail mower instead of a rotary cutter? /forums/images/graemlins/confused.gif
Bob
   / Flail Mowers
Bob
   / Flail Mowers #11
I have a six foot alamo (mott) Cuts the grass great near golf course quility. Great over rough terrain and works even better in the flat throughs nothing will cut high stuff small trees with ease.
Very expensive mine $3600 new for three point. A real bear at over 1000 pds.
   / Flail Mowers #12
   / Flail Mowers
</font><font color="blue" class="small">( I have a six foot alamo (mott) Cuts the grass great near golf course quility. Great over rough terrain and works even better in the flat throughs nothing will cut high stuff small trees with ease.
Very expensive mine $3600 new for three point. A real bear at over 1000 pds. )</font>
So, I hear that it will make fine mulch out of anything it cuts, this true?
Bob
   / Flail Mowers
Bob
   / Flail Mowers #15
Meant to say throws nothing. Don't thinks it mulch's well dont pay much attention but will next time i cut.
   / Flail Mowers #16
   / Flail Mowers #17
I have New Holland TC33DA supersteer with a NH flail mower. I have been using for 2 years to mow about 6 acres of pasture.
The advantages are:
1 Not as long as rotary mower so you can get in tighter spaces. Also has a square back so you can back up to a fence, etc for a clean cut.
2 Doesn't throw rocks
3 Never needs sharpening
4 Does a good job of mowing and muching
Disadvantages:
1 Costs more to buy
2 Every couple of years you must replace 125-150 teeth (each with it's own bolt) about a days worth of work.
Overall I am happy with my desicion to buy a flail mower. Commercial highway mowing contractors use them because they hold up well and you can hit just about any kind of rock, etc without doing much damage to your equipment.
John
   / Flail Mowers #18
The advantages are:
Disadvantages:
1 Costs more to buy
John
   / Flail Mowers
</font><font color="blue" class="small">( I have New Holland TC33DA supersteer with a NH flail mower. I have been using for 2 years to mow about 6 acres of pasture.
The advantages are:
Disadvantages:
1 Costs more to buy
John )</font>
What kind (brand) of flail mower?
Bob
   / Flail Mowers
The advantages are:
Disadvantages:
1 Costs more to buy
John )</font>
Bob
iDrive TDS-2010H...
2017 BX2680 Sub Compact Utility Tractor (A61306)
2017 BX2680 Sub...
GRAIN BIN (A60430)
GRAIN BIN (A60430)
Towable T/A Flammable Liquid Transport Tank (A59228)
Towable T/A...
Enmark Z Spray (A53316)
Enmark Z Spray...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
