Fixing a 3pt blade
/ Fixing a 3pt blade #1
ericher69
Ontario Canada
2008 Kubota b2920
My 3pt snow removal blade was getting pretty sloppy so... I took it apart and fixed it! I started by drilling the elongated holes oversized and sleeved the pivot points adding a grease zerk. Here are some pics Sent from my iPhone 5s 64Gb using TractorByNet
/ Fixing a 3pt blade #2
Nice fix!!!! Is definitely stronger than when new. Should serve you well for a long time.
You got a large 1/2" drill that you used??? I've got a Dewalt. Man, that thing will get away from you easy. Will turn a revolution, winding up your hands, after the go button is released!!! :)
Nice fix!!!! Is definitely stronger than when new. Should serve you well for a long time. You got a large 1/2" drill that you used??? I've got a Dewalt. Man, that thing will get away from you easy. Will turn a revolution, winding up your hands, after the go button is released!!! :)
Thanks!
No used an air powered drill and 1-3/8" hole saw. A short video https://vimeo.com/143868067
An air drill will stall out instead of breaking an arm or worse.
/ Fixing a 3pt blade #4
Thanks!
Very good idea!!! And I was wondering how you centered the hole saw. Now I get it. I'll use that method next time. Thanks for sharing.
/ Fixing a 3pt blade #6
Cool. Nice and simple, safe and effective. I wanted to do the same thing with my old Kewaunee, but it's a solid 3" dia. cylinder, with a solid 1 1/2" shaft running thru it. I may try some brass shim stock, wrapped around the shaft, to tighten it up.
ok make sure to start a thread so we can see your repairs
/ Fixing a 3pt blade #8
Top job!
BUSH HOG 4R48" BEDDER (A64278)
BUSH HOG 4R48"...
2003 CASE 590 SUPER M SERIES 2 BACKHOE (A65053)
2003 CASE 590...
2017 Jeep Grand Cherokee SUV (A64557)
2017 Jeep Grand...
SHOPBUILT 3PT CULITVATOR FRAME (A64278)
SHOPBUILT 3PT...
2022 EZ-GO ELITE...
CATERPILLAR D3GXL CRAWLER DOZER (A65053)
CATERPILLAR D3GXL...
