Fixing a 3pt blade
/ Fixing a 3pt blade #1
ericher69
Ontario Canada
2008 Kubota b2920
My 3pt snow removal blade was getting pretty sloppy so... I took it apart and fixed it! I started by drilling the elongated holes oversized and sleeved the pivot points adding a grease zerk. Here are some pics Sent from my iPhone 5s 64Gb using TractorByNet
/ Fixing a 3pt blade #2
Nice fix!!!! Is definitely stronger than when new. Should serve you well for a long time.
You got a large 1/2" drill that you used??? I've got a Dewalt. Man, that thing will get away from you easy. Will turn a revolution, winding up your hands, after the go button is released!!! :)
Nice fix!!!! Is definitely stronger than when new. Should serve you well for a long time. You got a large 1/2" drill that you used??? I've got a Dewalt. Man, that thing will get away from you easy. Will turn a revolution, winding up your hands, after the go button is released!!! :)
Thanks!
No used an air powered drill and 1-3/8" hole saw. A short video https://vimeo.com/143868067
An air drill will stall out instead of breaking an arm or worse.
/ Fixing a 3pt blade #4
Thanks!
Very good idea!!! And I was wondering how you centered the hole saw. Now I get it. I'll use that method next time. Thanks for sharing.
/ Fixing a 3pt blade #6
Cool. Nice and simple, safe and effective. I wanted to do the same thing with my old Kewaunee, but it's a solid 3" dia. cylinder, with a solid 1 1/2" shaft running thru it. I may try some brass shim stock, wrapped around the shaft, to tighten it up.
ok make sure to start a thread so we can see your repairs
/ Fixing a 3pt blade #8
Top job!
2023 Giddy Up USA 13ft. S/A Enclosed Cargo Trailer. (A64557)
2023 Giddy Up USA...
2015 Scag Turf Tiger 60in Zero Turn Commercial Mower (A64553)
2015 Scag Turf...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
