Fixing a 3pt blade
/ Fixing a 3pt blade #1
ericher69
Ontario Canada
2008 Kubota b2920
My 3pt snow removal blade was getting pretty sloppy so... I took it apart and fixed it! I started by drilling the elongated holes oversized and sleeved the pivot points adding a grease zerk. Here are some pics Sent from my iPhone 5s 64Gb using TractorByNet
/ Fixing a 3pt blade #2
Nice fix!!!! Is definitely stronger than when new. Should serve you well for a long time.
You got a large 1/2" drill that you used??? I've got a Dewalt. Man, that thing will get away from you easy. Will turn a revolution, winding up your hands, after the go button is released!!! :)
Nice fix!!!! Is definitely stronger than when new. Should serve you well for a long time. You got a large 1/2" drill that you used??? I've got a Dewalt. Man, that thing will get away from you easy. Will turn a revolution, winding up your hands, after the go button is released!!! :)
Thanks!
No used an air powered drill and 1-3/8" hole saw. A short video https://vimeo.com/143868067
An air drill will stall out instead of breaking an arm or worse.
/ Fixing a 3pt blade #4
Thanks!
Very good idea!!! And I was wondering how you centered the hole saw. Now I get it. I'll use that method next time. Thanks for sharing.
/ Fixing a 3pt blade #6
Cool. Nice and simple, safe and effective. I wanted to do the same thing with my old Kewaunee, but it's a solid 3" dia. cylinder, with a solid 1 1/2" shaft running thru it. I may try some brass shim stock, wrapped around the shaft, to tighten it up.
ok make sure to start a thread so we can see your repairs
/ Fixing a 3pt blade #8
Top job!
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
John Deere 5220 53HP Loader Utility Tractor (A64194)
John Deere 5220...
2025 JOHN DEERE 333P SKID STEER (A65053)
2025 JOHN DEERE...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
46184SFL (A64557)
46184SFL (A64557)
