First Tractor
/ First Tractor #1
Anonymous Poster
Epic Contributor
I just purchased 155 ac with about 40 ac of (2) fields. I plan on raising bison, and will be growing grasses, hay, and planting a few smaller plots for the native animals (deer, turkey, etc).
I'm pretty convinced to go with the Kubota, and am leaning toward the L4610 HST vs the M series.
Does anyone think the 4610 is overkill ? Would one of the smaller L series be more than plenty ?
I would do various dirt work with the FEL, mow / shred, and disk / plant as mentioned above - again 35-40 acres max.
RM
/ First Tractor #2
Nickel,
With that much land I sure would not go smaller. If you plan to bale hay, you should check power requirements for the type of baler you are interested in. Might be that a larger tractor is what you will need in the long run.
Sure wish I had that many acres to work with and I hope you will keep us in touch as you start in the "bison biz". (Just had to say that)/w3tcompact/icons/smile.gif
MarkV
/ First Tractor #3
I have 50 acres and have a Kubota M8950 and I pull a Rhino 15' Flex Wing mower. At the time I thought it would be too big, but I am glad to have it. If I were you, I would look at the M5700 at a minimum -- IMHO.
You may find the attachments you will want in the future require more HP than the L-Series can give you.
Regards,
Dave "Gatorboy" Hoffmann
Fallston, Maryland
/ First Tractor #4
nickel: think u would be well advised to follow gatorboys advice. seems like u have a lot of work u want to do, and the m series might be better for u. but i definetlly would not go smaller.
/ First Tractor #6
As a Kubota dealer, I have many customers who are doing the same thing as you intend to do. The M series 5700's & 6800's have the horsepower and ground clearance you will need to power your mower conditioner, hay rake, tedder, sprayer, and baler. They also have they weight you need to pull a disk and a planter. They come with the remote hydraulics you will need to operate all of these machines. Both the M5700 & M6800 are available in a hydraulic shuttle so they are very easy to operate. You can even finance the M series for 6 years vs. 5 with the L's. Dollar for dollar you get more machine with the M's vs. the L's and more is definitely what you will be needing. - IMO
www.aldermans.com
Frontier Grapple (A64127)
Frontier Grapple...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
Gas Powered Air Compressor (A66408)
Gas Powered Air...
378908 (A61166)
378908 (A61166)
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
