First time drilling post holes
/ First time drilling post holes #41
AGGIE00,
Are you using a skidsteer or a tractor with ssqa?
I considered the front mount hydraulic auger setup and rented one to use on a job but found it necessary to have a spotter since the auger was directly ahead of the tractor cowling. So I went with a rear mounting on my backhoe which makes it easy to see and control.
Much more reach than a fel mounted unit too.
I made a bracket that slides over my pallett forks and slid them over to the side so I can see the bit on the ground. This way I have a little flexibility.
/ First time drilling post holes #42
So you're setting a post on loose dirt? I guess I just don't like the idea, though I can't say for sure it's bad.
Not sure why anyone would be hanging or pulling on a PHD? That certainly wouldn't be safe, but I've never seen the need.
The last time I used mine before I got rid of it, a buddy chose to hang on the back of mine because of the hardpan followed by clay underneath it. I wasn't crazy about him doing that; but it was his choice. Fortunately nothing nasty happened.
/ First time drilling post holes #43
So it is bad to have a small amount of loose dirt in the bottom of the hole when the post is set, but ok to wallow out the hole?
Didn't I say that I didn't know if it was bad? I just don't like the idea, it seems like a good place for water to sit.
Who's wallowing out the hole? A very slightly rock doesn't make much difference in the hole at all, at least not enough to see with my eyes. Regardless, I'm backfilling and tamping either way. What's another 1/2" in diameter?
/ First time drilling post holes #44
Mounted on the backhoe you have lots of flexibility to dig the hole in the right place. I build and install wrought iron gates which require massive holes with lots of concrete. This works well for me since I often have to reach over low walls and obstructions.
Attention (A57148)
Attention (A57148)
NEW HOLLAND LB75 BACKHOE (A63291)
NEW HOLLAND LB75...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
EZ Trail 3400 (A63688)
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
