First time drilling post holes
/ First time drilling post holes #41
AGGIE00,
Are you using a skidsteer or a tractor with ssqa?
I considered the front mount hydraulic auger setup and rented one to use on a job but found it necessary to have a spotter since the auger was directly ahead of the tractor cowling. So I went with a rear mounting on my backhoe which makes it easy to see and control.
Much more reach than a fel mounted unit too.
I made a bracket that slides over my pallett forks and slid them over to the side so I can see the bit on the ground. This way I have a little flexibility.
/ First time drilling post holes #42
So you're setting a post on loose dirt? I guess I just don't like the idea, though I can't say for sure it's bad.
Not sure why anyone would be hanging or pulling on a PHD? That certainly wouldn't be safe, but I've never seen the need.
The last time I used mine before I got rid of it, a buddy chose to hang on the back of mine because of the hardpan followed by clay underneath it. I wasn't crazy about him doing that; but it was his choice. Fortunately nothing nasty happened.
/ First time drilling post holes #43
So it is bad to have a small amount of loose dirt in the bottom of the hole when the post is set, but ok to wallow out the hole?
Didn't I say that I didn't know if it was bad? I just don't like the idea, it seems like a good place for water to sit.
Who's wallowing out the hole? A very slightly rock doesn't make much difference in the hole at all, at least not enough to see with my eyes. Regardless, I'm backfilling and tamping either way. What's another 1/2" in diameter?
/ First time drilling post holes #44
Mounted on the backhoe you have lots of flexibility to dig the hole in the right place. I build and install wrought iron gates which require massive holes with lots of concrete. This works well for me since I often have to reach over low walls and obstructions.
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
Unverferth 632 (A64119)
Unverferth 632...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
