First Post - 2015 5600 Toolcat
   / First Post - 2015 5600 Toolcat
Some good news! It seems the issue with the auxiliary flow was simply about coil on the valve. They fixed up the AC system as well, so I'll grab it on Friday and get to mowing with my finish mower!
   / First Post - 2015 5600 Toolcat #12
That's some good news!
   / First Post - 2015 5600 Toolcat #13
Yep, good news :thumbsup:.
To keep cool when mowing, carry a brush in the cab that you can use to brush off the condenser coil behind this side door:
   / First Post - 2015 5600 Toolcat #14
I found that a paint filter for 5 gal pails work good as a dust filter. Just open the side door, slip the paint filter over the door, then close the door. After mowing, pull the filter off the door and shake it out. Dandelion season is here and the white fluff will pack it full. They do sell a side screen kit that fits inside the door #7199661.
Very good advise guys! I'm picking it back up this evening, and with any luck will get the place mowed this evening.
We'll she up and running, mowed my first 4 acres with it, and I'm very impressed, especially with the AC!
Might need to find some more turn friendly tires. Any suggestions?
Hey, I found the big long posts on tires, so I'm good there!
   / First Post - 2015 5600 Toolcat #18
What problem are you having with turns?
Our G Series doesn't have any that I know of.
   / First Post - 2015 5600 Toolcat #20
The factory turfs on a G series is a 29x12.5-15 8 ply tire made by Titan. PN 7166360
Titan 4748L5 Commercial Multi Trac C/S is the tire I think it is.
There is also the Carlisle turf master/multi trac C/S 10pr 560478
These will take a wider wheel than the other tires because they are WIDE. Also, they have to be a stiff tire for the heavy toolcat.
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2017 ford explorer (A56859)
2017 ford explorer...
2018 Ariens Ikon 52in Zero-Turn Commercial Mower (A56857)
2018 Ariens Ikon...
2021 Caterpillar 272D3XE High Flow Compact Wheel Loader Skid Steer (A55973)
2021 Caterpillar...
Jacobsen three wheeler mower (A56857)
Jacobsen three...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
