first knife so far.
   / first knife so far.
Thanks very much to all. Starting on the next one to give to my dad. Pic is of steel with outline and one with roughed out profile. Next is drilling the handle pins and lanyard holes, grind the edge and then start heat treating.
   / first knife so far. #13
I've picked up several large whitetail antler sheds over the years. I've always wanted to make them into knives but never have. A knife forge for $50 may just change my mind.
*adds make knife to list of stuff to do*
   / first knife so far. #14
Wow, nice work. And eve featured on the cover of Field & Stream:D
What steel/alloy are you using for the blade? Do you know how hard you are getting it to when you are all said and done?
   / first knife so far. #15
If guys in prison are allowed to read TBN then you are now in their wet dreams! Looks great, I always wanted to make a machete with some weight on the tip.
Thought I'd put a couple of pics on a second similar knife. First is a pic of the stock I use, second is after grinding and heat treating and third is after cleaning off the scale and doing some light sanding, but still able to see the effects on the metal after heat treating. Next is the handles.
Here is the third pic I mentioned.
   / first knife so far. #18
NICE ! What temp do you heat to and how long do you quench...quench in oil or water ? where did you find the forge ? what is it's fuel ? oxygen ? sorry bout all the questions...but inquiring minds gotta know ! :laughing:
Rich
   / first knife so far. #19
Nice shape to the knife. What type of steel is it?
The temp is around 1800 degrees or so, not really sure. I use the magnet test. When the metal is about whit hot I touch the blade to a magnet and if there is no attraction then its ready. I quench it in canola oil. The forge is a small fire brick I made. Been trying to post a short vid but can't get it to work. The steel is 1095.
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2008 New Holland B110 MFWD Loader Backhoe (A51039)
2008 New Holland...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A49461)
2012 Ford F-550...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
