first experience with magic jack
/ first experience with magic jack #21
Here is a link that helps to explain everything having to do with the use of Magic jack,
MagicJack/Support Resources/FAQ - Wikibooks, open books for an open world
Hmmmm, Soundguy, did your wife have caller ID blocked?
http://en.wikibooks.org/wiki/MagicJack/Support_Resources/FAQ#How_do_I_block_anonymous_callers.3F said:
As of November 2011, MagicJack blocks all anonymous caller ID by default, and has stated that this cannot be changed. Incoming calls must unblock caller ID or they are played a MagicTalk advertisement message, then informed that the call cannot be connected. There is no explanation given in the outgoing message, just a recommendation to contact the caller's own customer support.
Globalstar doesn't deliver CID. Most phone systems let you punch in a number to bypass 'no CID reject". MagicJack doesn't so you can't call MagicJack lines from Globalstar
Aaron Z
/ first experience with magic jack #22
As a newby to this concept, who would I go see to set it up in my home? Would I get to keep my number I have now? Is it a good trade-off for getting rid of the landline?
You need broadband internet. I couldn't keep my number but that was years ago.
The cool thing about ditching your old number is it stops the telemarketers for awhile. The audio quality is like a land line from my experience.
Calls used to be limited to 2 hours and it cuts you off. Now it's down to 1.5 hours. You can't redial right away but after maybe 5 minutes it lets you redail
that number. there is a running clock in the pop-up MJ window that shows how long you've been on the phone. Sometimes you get glitches during calls.
i read the lengthy wiki article. almost thought i had it figured out with the priority call list.. but that sends you to voicemail... and we were geting a magic jack add .. as if the call was from a blocked phone. I know for a fact that neither my wifes cell nor the school's phone have blocked CID. so I'm guessing it is another undocumented feature most of us call 'bugs!' :)
2017 Jeep Renegade SUV (A61574)
2017 Jeep Renegade...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2021 CATERPILLAR 306 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
2003 Ford F-350 Flatbed Sprayer Truck (A61573)
2003 Ford F-350...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
