Firewood processor help
/ Firewood processor help #111
What happens in your country when a commercial or industrial accident happens?
Do the safety police come around and make you change things?
The speed of your saw and cyl seem good enough.
I still want to know the log splitter pressure developed at max cyl extension.
Different logs will develop different pressure because of the work being done.
From your data, I am understanding that you can not achieve a pressure over 1330 psi on any log or the motor will begin to stall. So, if that is true, then the relief valve for the log splitter should be set to 1270 psi.
Does automation mean to you, that by pressing one button, all the functions work without hands on.
OR
Are you talking about semi-automatic by you having to press one button at a time for the function to operate.
What happens in your country when a commercial or industrial accident happens?..well, in this case, without certifications and machine licensing, i am f****..the insurence dot not cover any damage..
Do the safety police come around and make you change things? this machine is half homemade, so safety police does nor aplly here..problably i have to stop working with the machine..or change it for safety standards..
The speed of your saw and cyl seem good enough. well, i think is to slow, but, is what i have..for now..
I still want to know the log splitter pressure developed at max cyl extension. To know that, i have to shut off an inductive sensor that makes cylinder stop before the end of the stroke..problaby, is what iエm going to do to set up reliefs wright..I donエt see any other way to do that
Different logs will develop different pressure because of the work being done. yes, i know
From your data, I am understanding that you can not achieve a pressure over 1330 psi on any log or the motor will begin to stall. So, if that is true, then the relief valve for the log splitter should be set to 1270 psi. NO! in splitter hight pressure mode only the 12,7 pump works, so, with 25 HP, I should be able to put much more than that, around 2900 PSI..so my splitter 12,7 GPM pump relief is going to be around 2800 PSI)
OR
well, both..i am going to set up 2 or 3 diferent automatic or semi-automatic programs..the max automation i can do with this setup is, by pressing one button, all the functions will work step by step, in repeated cycles, untill there is no wood in log feeding..maybe in future i can put some kind of sensors in log deck so the machine can work completely by itself..but that isnエt easy..all the logs have diferent sizes..think to do this, i will need a step log feeder..
/ Firewood processor help #113
There are some things you could do.
Larger electric or another electric motor driving just the log slitter pump .
Excerpt: from a log splitter manufacturer.
If you want to get a lot of work done and fast, pony-up for the 5X24 welded cylinder & our NEW blazing fast 28 GPM pump (make sure to get the 3/4" log splitter valve) to split 30 Tons with less than 10 second cycle time (unloaded). A 16 HP motor minimum is required for required for gas, and maybe less HP for electric driven.
There is usually a short burst of high pressure flow to get the split started, then the high flow /low pressure takes over.
A smaller hyd cyl will provides more speed.
Is the majority of the wood you want to split very hard.
Higher pressure will only increase tonnage.
Had a friend of mine that used a hyd accumulator to supply the flow to split wood. It was lightning fast, almost exploding some of the wood. It did not last long as it was to powerful.
Consider a 2 gal accumulator at 3000 psi. I watched from a distance.
today afternoon we were trying to set up saw and saw cylinder reliefs..
It happen one curious thing, that I don´t Knew..maybe Mudstoper tried to explain it to me, but i could not understand it that way..
we set up the pressure regulator (or relief, i don´t have sure) for saw cylinder for the minimum, and set the flow valve at max for this same saw cylinder.
..So, the saw was working at good pressure relief, behond max for my 25 HP, but my saw cylinder, as it have is own pressure regulator, was working at very low pressure, but at high speed (flow)
What do you think it happens?:)
Well, motor shut off..i think .404 pitch (with 0,039 in deep gauges) has its own "will" to move forward through the wood, and maybe that's why harvesters chains have minimum required cut power, as if you let the chain move itself through the wood, you will need some good HP numbers..
So, we put no pressure on saw cylinder, and chain "push" down cylinder untill it stops..
Do you think was this what happen?
/ Firewood processor help #115
I watched your utubes and the saw seemed not to be cutting the way I have seen others. It just seemed to be slow and was it stopping or was you stopping it? That 404 chain is it one of these, 27R, 16H, or 18H? If so and it's good sharp should cut like butter with that log you were cutting in the utube.
Well, is not that simple..the saw is a litlle slow, yes, just because i don´t have enought source HP to power it....it stops when we give more flow to the saw cylinder and consequently more speed, so it's stops..that´s what you saw in the video, we were messing around with saw cylinder flow..
My .404 chain is a stilh MRHS harvester chain with 0,080in drive link gauge and 0,039in deep gauge..this is too much for this configuration..one of this days i am gonna put in a 3/8 pitch with 12 tooth sprocket and see the diference..think is going to cut faster than .404
It was a new chain..as a good new sharp..that log was a eucalyptus log..if i put some soft wood in it, it should cut better..but lack of torque is the problem..can´t put it better, since I only have 25 HP and a 8,9 GPM pump for it..
/ Firewood processor help #117
I might have this wrong, as I didn't have time to read the full thread, but I understand you are having problems with the saw motor stopping during the cut? Given that I assume you have a sharp chain, it sounds like you are trying to regulate the saw motor load by controlling the flow of the ram that lowers the saw, and it is applying too much pressure. I personally don't think flow control is best way to control speed of cut, but if you are using this method surely all you need to do is restrict the flow a little more?(close your flow control valve more). You also need to have the pressure relief set high as possible for the saw motor, because cutting is the thing that takes the most power(along with the splitting ram, which at times, also uses alot of power).
There are a couple of other ways of preventing the the saw motor relief from blowing....One is reasonably complex and envolves a fitting that constantly senses the load on the saw motor, and slows the oil flow to the saw drop ram as more load goes on. In this system the speed of the bar drop is constantly varying to match the motor's load.
A more simple way is by using an (adjustable) pressure reducing valve to the saw drop ram to apply downward pressure on the bar (just like we can do with our hand held chainsaw).
According to Oregon, a 404 harvester chain should have approx 50lb (23Kg) pressure on the log measured at mid bar. You can still use a flow control valve to get the bar to lower to the log at the correct speed, but the the pressure reducing valve will LIMIT the amount of pressure applied. It's my understanding that most commercial harvester set-ups like this use about 40-50hp, so you might only need less than half this...maybe just a few pounds pressure?
A normally open pressure reducing valve senses the downstream pressure, and will close when the set pressure is reached, therby regulating the pressure exerted by the ram, and therefore regulates the bar and chain pressure during the cut. (Tip...If you make the saw decend by retracting the ram(instead of extending the ram), you can use a higher hydraulic pressure, or, alternately, if your pressure requirement is very low, you can use two pressure reducing valves so that the ram pushes against a set back pressure. By one of these methods you can control the bar pressure quite accurately.
Of course the Russians just use a spring! Just like their cosmanauts used a pencil in outer space!!
Oregon have available formulas for calculationg the rate of cut for a particular power input (for instance a .404 50Hp saw going the correct chain speed should cut a 12" dia log in less than 1 second!)
I thought your chainsaw was cutting fairly slow (did I read you have 15 h.p.?...if so it should be faster!!) My larger handheld Jonsered chainsaw cuts that fast and is less than a third of that horsepower. So I'm wondering if you are perhaps not putting enough of your available power into the saw motor, by having your pressure relief set too low?
When you are cutting with the chainsaw, your (electric)motor should be under near full load). You can increase the load on your electric motor with a higher pressure relief setting. Use an electrical amp load indicator to see how hard the electrical motor is actually working! (Every electrician should have one).
In regard to the chain coming off, this happens sometimes when the chain stops before the saw is retracted. To prevent it, try a lower spring pressure (5 psi) on the one way non-return valve that allows the saw motor to overun...this will let it slowdown less abruptly, by which time you should have lifted the bar. You want the chain still going around as you lift. Alternately, configure the saw motor to still be going after the cut, until the saw is lifted.
johndeerkiwi ,
Well, automation donne..tomorrow the machine is going to start working for firewood production..
Got definitively to do do something to that saw..is slow enought..i read what you wrote, and think is very well explained and makes all the sense..so here my circuit:
saw cylinder with 2in bore and 1,5in rod, pushing the saw down when it extends..so it is contrary to what should be, think i understand this part..the cylinder is way to big, should have less thickness ..with this I have now, if i aplly to it only 50 PSI, even so it will be putting on the saw bar 140 lbs, witch is way to much..and think can no work go with 50 PSI..so another issue here..
the circuit have two flow regulators..one instaled before the cylinder witch controls cylinder extend, and another after, controling the retract..don´t have sure if this is putting some problems there to..
the saw circuit, wich is feed by a 8,9 GPM pump with a limit of around 2600 PSI continuous, is feeding both saw cylinder and saw motor (parker F11-010 with 0,62 cu in displacement). The main block valve for this circuit have a relief valve , and at the top of this block there are two solenoids, one for saw control, and another for saw cylinder..wright before saw cylinder solenoid valve, there is a pressure control valve (on top of main valve block and before the solenoid), that is regulating only saw cylinder line pressure..(this part is confusing me to think about it, there is one relief for both lines, plus one pressure valve for one of that lines?!?!?!)
So, if i understand what you mean, I could resolve the problem by putting another pressure control valve in the line that returns to main block valve, after going trough saw cylinder, providing some "back" pressure, so i control saw bar descend? and, well, 8,9 pump should be replaced for a bigger flow pump too..think 8,9 GPM for both saw cylinder and saw motor is quite low..torque should be higher, so I can put that saw going trough the wood at more speed..it is so slow, that I am ashamed to show..
well, here is the video of automatic mode working..almost 35 sec for each cycle..:thumbdown:
Manual mode (sorry, we don't have the skills yet to move functions at the time, so please pay only attention to the saw)
we change the 404 pitch to a 3/8 pitch..the rest it´s all the same, even sprocket..regard in the video that as the cuttings go on, we here manipulating the saw cylinder flow control, so we can test how far the new pitch can go with the limited power available..
Well, mudstopper and others have already warned me for this..the cut still's slow, but now is at around half of time compared to the 404 pitch..
Conclusion: if don´t have power for it, don´t go for a .404:mur:
/ Firewood processor help #120
I thought you where going to try and plumb the 30gpm splitter pumps into your saw motor. I think with your current saw motor and oil flows, its going to be hard to get a lot of chain speed and still have cutting power. I think I also mentioned that with your current setup the 3/8 chain might be a better choice. Using a motel computer so I cant see the videos until I get home. You say the say is slow, but if you can figure out a way to plumb your splitter pumps to work with your saw motor, it should be a badass saw. You wont be able to saw and split at the same time, but at least you should be able decrease the 35sec cycle times considerablely.
Flow controls only work in one direction, I believe you said you are using 2 seperate flow controls on you saw cylinder. You might try removing one of them so that the bar is fast in one direction and slow in the other. A 2.in bore cyl is a big cyl to push the saw thru the wood. If you can revese the cyl mount so that it pulls the saw instead of pushing it, that will help with reduceing down force on the bar and increase feed rate. It will work if you can get the flows right as well as the pressure low enough that it doesnt break the bar off its mounting bolts.
TEREX TH8440 TELEHANDLER (A60736)
TEREX TH8440...
John Deere 50 (A60462)
iDrive TDS-2010H...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
