Firewood Gathering With A Power Trac
   / Firewood Gathering With A Power Trac
There is probably another full load left in the pile, so that means that stack of logs in the first picture will yield about 3 cords total. I need about three more cords to be happy, so that means one more day felling, one more day dragging, and several trips with the trailer bringing it all home. Then I can start splitting the larger ones and stacking it to dry.
The next time I fell and drag I will try to take some photos and maybe a movie or two. :)
   / Firewood Gathering With A Power Trac #12
MR,
Do you have a pic of your woodburner?
When I built my house about 4 years ago, I purchased a small wood burning stove:
Vermont Castings NC Wood Stoves
ASPEN 1920
ASPEN - 1920 Stoves | Wood Stoves - Non-Catalytic Wood Stoves by Vermont Castings
It was just going to be for an occassinal fire, and mostly just for looks. I had never had any experiance with a wood burning stove before.
After we started using it (and calculating the cost with and without for heating) we really enjoyed it, and burn all winter long (Michigan: Nov - Mar).
But, I would suggest to anyone getting a wood burning stove to go larger, not smaller (just like out buildings). The one I have does fine to keep our hallway, kitchen, dining, and living room warm, because these rooms are an open design. Plus we like our bedrooms colder for sleeping. But the stove I have is hard to load, and you have to cut the wood/logs very small to load the stove. And if you load it correctly, and damper it all the way down at night before going to bed, in the morning (7-8 hours) you usually have some coals left to fire up another load. But not much, so you can't doddle, get side tracked or sleep in.
If I had it to do over, I would:
-locate the stove in the center of house (or close to)
-get a larger stove (2000 btu's plus, to cover 1800-2400 sqft. easily)
-one that has a large (length wise) front door (or double door)
-one that has a large ash drawer, and removable without openning the door
-and buy one of these:
TractorByNet.com Classifieds Item 831287742 - Aspen wood stove fan - Runs on heat
(btw, am I just a slow typer, or does this reply board "time out" quickly"?)
This is the model stove we have.
Napoleon Wood Burning Stoves
Although ours is all black with no fancy schmancy trim! :D
We put ours on an outside wall in the basement for several reasons.
1. That is the only place it would fit without major remodeling of the upstairs.
2. We wanted to be able to use our basement in winter. It gets down in the high 40s if it is below zero outside.
3. The firewood comes in through an outside stairwell, which keeps the dirt down.
Goal was to use 50% less gas and we did more than that this winter and this winter was colder than last winter. Mission accomplished! :)
I also plumbed in some ductwork above the stove and used an in-line booster fan with a thermostat to send warm air upstairs. That worked well. When temps are in the mid 20s or higher, I can maintain the entire house at 72-74 degrees.
I used a portable thermostat like this
Portable Thermostat | Heaters | Northern Tool + Equipment
in the basement to control the air flow to the upstairs. It is reversible for heating or cooling. I have it set so that when the basement heats up to 72 degrees, it turns the duct booster on and sends the heat upstairs, thus "cooling" the basement. When the stove dies down and the temp in the basement drops below 72, it turns off the fan so that cold air is not moved upstairs. Works well.
   / Firewood Gathering With A Power Trac #14
Nice!
MR, would you mind (if possible) giving a drawing of how you did that (you know, a pic worth a 1000 words)?
Also, can you give an approx. on the cost of that stove?
Nice!
The stove was about $1500.00.
The chimney pipe was about $1000.00
And the company I bought all that from installed it for $500.00. That entailed cutting a hole in the 1st floor's floor, the 1st floor ceiling and the roof.
I boxed in the pipe after they were done.
Not sure what drawing you want?
   / Firewood Gathering With A Power Trac #16
Moss, are you using the outside combustion air feature?
Nope. I'm using the "my house is so drafty I can fly a flag in the hallway" feature! :D When I light the stove and sit on the floor in front of it, I can feel the air rush across the basement floor and under the stove.
One thing I should mention is that I installed a smoke and carbon monoxide detector directly above the floor vent where the air comes out on the first floor. That way, if anything should go whacky in the basement and I start sucking gasses upstairs, it will go off fast. And it works, because I had some smoke drift out of the stove when I opened the door one day. :rolleyes:
I brought another load of wood home on Friday but it is raining today, so I'll have to wait until later this week to get that last load before felling more trees. :(
   / Firewood Gathering With A Power Trac #18
We are thinking of getting one of those Napoleons in the next year, probably the same model as yours. Any regrets or tips?
I guess I am not picturing the hook up with the thermostat.
OK. I got it. Here goes.
The thermostat that I posted a link to is called a portable thermostat. It is a box with a 10' cord on it. At the end of the cord is a piggy-back plug that you plug in to a wall socket. Then you plug the device you want to control into the back of the piggy-back plug. The box has a coil on it to sense temperature and a dial that you set for the desired temperature, just like a home thermostat. Inside the box there is a terminal strip with several color coded screw terminals. The thing comes from the factory set to HEAT. That means, if the temperature DROPS below the point you have set on the dial, it will turn ON anything that is plugged into the piggy-back plug. These things are used in greenhouses to turn on heaters at night. However, by changing a couple wires on the color coded terminal screws in the box, you can have it set to COOL instead of HEAT (the directions come with it, just takes a screwdriver, very easy). When set to COOL, if the temperature RISES above the point you have set on the dial it will turn ON anything plugged into the piggy-back plug, like an air conditioner.
So, now on to the basement room where my stove is.... I have installed some simple duct work between the basement room and the 1st floor. Inside that duct work is a booster fan that runs on 110V. I plugged that booster fan into the back of the piggy-back plug on the portable thermostat. I light a fire in the stove and in about an hour the room starts to heat up. I have the thermostat set to 72 degrees and configured to COOL the room. So, when the temperature in the room rises above 72 degrees, the portable thermostat turns on the duct booster fan and moves the warm air out of the basement and up to the first floor. In about 6-7 hours the fire goes out, the stove cools down, the temp finally drops below 72 and the thermostat shuts the duct booster fan off so no cool air moves upstairs.
Pretty slick. I came home yesterday after noon and the fan was running but I didn't make a fire for two days. Apparently the sun had shone through the basement windows, heated up the room to above 72 and it sent warm air upstairs for a while in the afternoon. Free heat! :D
2009 CATERPILLAR AP1000D ASPHALT PAVER (A60429)
2009 CATERPILLAR...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
FORD 545D TRACTOR (A60430)
FORD 545D TRACTOR...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
2019 F150 (A56438)
2019 F150 (A56438)
