Fire Extinguisher for the Tractor
   / Fire Extinguisher for the Tractor #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I have an old Kiddie home fire extinguisher in my dozer that I've never used, but thought it was a good idea to have one when working around the burn pile.
Last weekend, I lit my burn pile and kept an eye on it in my new cabbed tractor. I thought I saw some ash float down on top of my fuel tank, which caused me to think how dangerous that could be. I never found the piece of ash, but it got me to thinking that if my tractor caught on fire, what would I do?
Any fire extinguisher is better then nothing. But I'm wondering if there is something specific that I should look for to put out a fire on a tractor full of hydraulic oil?
I'm also curious where to mount it?
Thank you
   / Fire Extinguisher for the Tractor #2
I keep a small ABC extinguisher laying in the cab of my tractor.
Flying embers are not going to ignite hydraulic fluid or diesel, but it's always best to be prepared.
I think the best fire prevention is keeping a tractor clean of oil, diesel, and vegetation debris.
   / Fire Extinguisher for the Tractor #3
A decent small auto/marine extinguisher will give peace of mind. Any one would be better than what I have on mine now, which is nothing. Mounting spot - roll bar; or for a cab - somewhere handy but out of the way...
   / Fire Extinguisher for the Tractor #4
ABC extinguishers on my mowing rig - 2 because if you need 1 you might need 2 and what if 1 fails?
   / Fire Extinguisher for the Tractor #5
I've had flying ambers lite diesel. So be aware. (y)
   / Fire Extinguisher for the Tractor #6
I would like to get a mount for one of my big water extinguishers for my Toolcat. I'm not sure where I could mount it though.
   / Fire Extinguisher for the Tractor #7
ABC extinguishers on my mowing rig - 2 because if you need 1 you might need 2 and what if 1 fails? View attachment 873214
I learned the hard way the small extinguishers don’t last long. 6-8 seconds? I now have more handy and a couple of larger ones.
   / Fire Extinguisher for the Tractor #8
Tow it?
   / Fire Extinguisher for the Tractor #9
Real good example scootr! I tried to enlarge to see the mounts better but no luck. Can you explain what type of mount that is and where you got it please? I'd like to copy your idea cause it'll make me feel safer out in the field. It "looks" like a fitted holster style with "perhaps" Velcro straps? I'm probably way off base but that's a holder I'd like to find. Thanks, Greg
   / Fire Extinguisher for the Tractor #10
Looks good
My trouble with fire extinguishers is the mounting device I don’t think they will stand up to long term use on a tractor (bouncing) and to UV rays.
2002 Case SE 750HWT (A54865)
2002 Case SE...
Hose Reel (A53424)
Hose Reel (A53424)
2017 TRAVIS BODY & TRAILER END DUMP (A55745)
2017 TRAVIS BODY &...
TIRE INFLATION CAGE (A55745)
TIRE INFLATION...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A55852)
2022 Chevrolet...
1998 NATIONAL TRAILER (A55745)
1998 NATIONAL...
