Fire Extinguisher for the Tractor
/ Fire Extinguisher for the Tractor #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I have an old Kiddie home fire extinguisher in my dozer that I've never used, but thought it was a good idea to have one when working around the burn pile.
Last weekend, I lit my burn pile and kept an eye on it in my new cabbed tractor. I thought I saw some ash float down on top of my fuel tank, which caused me to think how dangerous that could be. I never found the piece of ash, but it got me to thinking that if my tractor caught on fire, what would I do?
Any fire extinguisher is better then nothing. But I'm wondering if there is something specific that I should look for to put out a fire on a tractor full of hydraulic oil?
I'm also curious where to mount it?
Thank you
/ Fire Extinguisher for the Tractor #2
I keep a small ABC extinguisher laying in the cab of my tractor.
Flying embers are not going to ignite hydraulic fluid or diesel, but it's always best to be prepared.
I think the best fire prevention is keeping a tractor clean of oil, diesel, and vegetation debris.
/ Fire Extinguisher for the Tractor #3
A decent small auto/marine extinguisher will give peace of mind. Any one would be better than what I have on mine now, which is nothing. Mounting spot - roll bar; or for a cab - somewhere handy but out of the way...
/ Fire Extinguisher for the Tractor #4
ABC extinguishers on my mowing rig - 2 because if you need 1 you might need 2 and what if 1 fails?
/ Fire Extinguisher for the Tractor #5
I've had flying ambers lite diesel. So be aware. (y)
/ Fire Extinguisher for the Tractor #6
I would like to get a mount for one of my big water extinguishers for my Toolcat. I'm not sure where I could mount it though.
/ Fire Extinguisher for the Tractor #7
ABC extinguishers on my mowing rig - 2 because if you need 1 you might need 2 and what if 1 fails? View attachment 873214
I learned the hard way the small extinguishers don’t last long. 6-8 seconds? I now have more handy and a couple of larger ones.
/ Fire Extinguisher for the Tractor #8
Tow it?
/ Fire Extinguisher for the Tractor #9
Real good example scootr! I tried to enlarge to see the mounts better but no luck. Can you explain what type of mount that is and where you got it please? I'd like to copy your idea cause it'll make me feel safer out in the field. It "looks" like a fitted holster style with "perhaps" Velcro straps? I'm probably way off base but that's a holder I'd like to find. Thanks, Greg
/ Fire Extinguisher for the Tractor #11
These are not good for oil fires, but they are my go-to extinguisher to use with burn piles. I have 4 of them, and always have at least 2 near a burn pile. I'll drag out all 4 if its a good size burn. I really like these.
You can recharge them yourself. After you use it, replenish the water, pressurize to 100psi using your air compressor. Ready to go!
They are really handy for putting the embers "dead out." Since you can recharge them easily, just blast away until they are exhausted.
/ Fire Extinguisher for the Tractor #12
Those are nice extinguishers. I keep one in my house, and in my previous life have knocked down several "room & contents" fires with a can.
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
New 2025 NextGen 7x12 Utility Trailer (A61166)
New 2025 NextGen...
2019 John Deere X380 Lawn Mower (A63116)
2019 John Deere...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
Bobcat T590 (A60462)
