Mowing Finishing Mower
/ Finishing Mower #1
gramer
I have a 23HP Yanmar tractor, should it be able to pull a 72" Big Bee finishing mower? I've noticed when I use mower the tractor will run hot after about 30 minutes of mowing, which it does not do when I use the front loader? The cutting arear is mostly level, with grass approx 6-10" high ..Any help is greatly apprecaited.....Thanks!
/ Finishing Mower #2
If that's 23 PTO HP, your Yanmar should be able to handle a 72" mower, but you'll need to keep that grass shorter then 6-10 inches. That's rather tall for a finished yard, isn't it?
Just run at a slower ground speed until you get that grass to a reasonable length or raise the cutting height a few inches (which means you may have to mow it twice).
BTW, if your mower's blades haven't been sharpened in a while...sharpening would help too.
If this is a field you're mowing, you should probably use a rotary cutter.
/ Finishing Mower #3
Wow. Just my reaction, take it for what it is worth, but a 6' mower is a bit much for a 23 hp CUT. Agree with Roy's observations. A finishing mower is intended more for lawns, at least that is what I use mine for. BTW, I pull a 4' finishing mower with my 23 hp tractor. I have pulled a 5' and it ran it just fine, but again, I mowing my yard, not a field of tough, tall grasses.
/ Finishing Mower #4
TOOOOO much grass for that cutter on that tractor. Ken Sweet
/ Finishing Mower #5
OK, so my F935 (23 hp when new) runs a 72" side discharge mower and will struggle in 10" grass and run hot if the radiator screen is a bit clogged (10" grass is going to seed in many cases) and the blades are dull.
So, I usually make several passes at raised height or reduced cutting width (48" instead of a full pass).
Cutting more often would solve your problem. A rear discharge offers reduced load vs. side discharge. If you have high lift blades, change them to regular ones. By any means keep them sharp.
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
LOT OF MISC BAR JOIST (A63291)
LOT OF MISC BAR...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2017 Ford Expedition SUV (A61574)
2017 Ford...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
