Mowing Finishing Mower
/ Finishing Mower #1
gramer
I have a 23HP Yanmar tractor, should it be able to pull a 72" Big Bee finishing mower? I've noticed when I use mower the tractor will run hot after about 30 minutes of mowing, which it does not do when I use the front loader? The cutting arear is mostly level, with grass approx 6-10" high ..Any help is greatly apprecaited.....Thanks!
/ Finishing Mower #2
If that's 23 PTO HP, your Yanmar should be able to handle a 72" mower, but you'll need to keep that grass shorter then 6-10 inches. That's rather tall for a finished yard, isn't it?
Just run at a slower ground speed until you get that grass to a reasonable length or raise the cutting height a few inches (which means you may have to mow it twice).
BTW, if your mower's blades haven't been sharpened in a while...sharpening would help too.
If this is a field you're mowing, you should probably use a rotary cutter.
/ Finishing Mower #3
Wow. Just my reaction, take it for what it is worth, but a 6' mower is a bit much for a 23 hp CUT. Agree with Roy's observations. A finishing mower is intended more for lawns, at least that is what I use mine for. BTW, I pull a 4' finishing mower with my 23 hp tractor. I have pulled a 5' and it ran it just fine, but again, I mowing my yard, not a field of tough, tall grasses.
/ Finishing Mower #4
TOOOOO much grass for that cutter on that tractor. Ken Sweet
/ Finishing Mower #5
OK, so my F935 (23 hp when new) runs a 72" side discharge mower and will struggle in 10" grass and run hot if the radiator screen is a bit clogged (10" grass is going to seed in many cases) and the blades are dull.
So, I usually make several passes at raised height or reduced cutting width (48" instead of a full pass).
Cutting more often would solve your problem. A rear discharge offers reduced load vs. side discharge. If you have high lift blades, change them to regular ones. By any means keep them sharp.
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
John Deere 7410 (A64119)
John Deere 7410...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
