Finished my forks
/ Finished my forks #1
leblaken
Magnolia, MS
JD 5105
I acquired some forks from and old fork lift and decided to attempt to build a bracket to hold them. I am very happy with the outcome.
/ Finished my forks #2
Boy those look heck for stout, How much can your FEL lift? They would be too heavy for my little Bota, but might be just right for your JD. looks like you did a great job.:thumbsup:
James K0UA
/ Finished my forks
The heaviest load I have picked up with it weighed 1100#. According to the spec sheet the loader is rated for 2400# at the pivot.
/ Finished my forks #4
How did you build the quick hitch between the loader frame and fork attachment? Looks good.
/ Finished my forks #5
Looks great, Now I would add a bulkhead above, allows you handle larger bulkier loads, especialy brush.
JB
/ Finished my forks
The quick hitch is a JD part that I welded on. It is designed to be welded on to the back of the bucket.
/ Finished my forks
JB4310 - I have the plans drawn up for the bulkhead just haven't built them yet. I thought about it after I finished the main bracket.
/ Finished my forks #8
Nice work! Nothing like getting a freebie?? Like you, I rec'd a set of forks and carriage from a forklift. I hope to post later this week. I too have to do the bulkhead to it as well.
Nice work, looks really good!!!:thumbsup:
/ Finished my forks #9
Holy cow!!! I would say they wrote the book of heavy duty about that thing. You have made something that will serve you and your grand kids will be able to pass it down saying it's been in the family since the early 21st Century.
/ Finished my forks #10
Looks excellent. I have some forks just like that but haven't gotten around to making a mount for them. Good job!
/ Finished my forks #11
leblaken,
Nice job on the fork adaptation. I did something very similar like that for my PT.
Here are some other ideas you might adapt.
/ Finished my forks #14
Looks good!
The only thing I would suggest (and I did to mine) is to put a 4" spacer on the bottom of your FEL mount.. this allows you to tilt your load farther back in the event you are going down hill.
Anyone have more info on the grapple attachment? I can fab that up pretty easy just don't know much about hydraulics..
/ Finished my forks #15
Looks good!
I'll second what camoman said. I found out my forks needed more curl after I built them. I think forks are the most useful attachment you can have.
John
/ Finished my forks #18
Very nice!
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
159115 (A60430)
159115 (A60430)
Doo Little XTM-8418 Trailer (A66285)
Doo Little...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
