Finally the barn.
/ Finally the barn.
Ok I'll try and post some of these in smaller batches.
Warning.. Some of these are not in focus, not sure if adult beverage will help. Some were so bad I won't even post them.
Lets start with why I wanted the barn. I have a small 2 1/2 car garage.
Let take a look shall we?
/ Finally the barn.
As stated earlier, the guy decided to back up my 500' driveway.
/ Finally the barn.
The crew arrived almost an hour before the materials.
Seemed like a good bunch of guys.. The have to drive a little over an hour each way every day to get out to my place.
/ Finally the barn.
Here are the last photos of the day..
They got most of the posts in and were starting to put top joist on.. They are using glue-lam for these top joists and they seem to be PRETTY heavy. So I'm guessing that's why they decided to call it a day. Also they included the wrong posts for the shed roof. They said they will bring the correct ones tomorrow.
/ Finally the barn.
DAY TWO.
Looks like they will put in about 6 hours a day.. They get there just before nine am and leave around three. But they do have over an hour to drive each way. The foreman told me they wont be done until Monday or later.
Ok here are some photos of the first truss going up.
/ Finally the barn.
Middle and end of Day Two..
I switched cameras to my SLR so I could hold it more steady. (steadier?)
/ Finally the barn.
End of Day Two.
/ Finally the barn. #29
Looks great!! :thumbsup: Nice spot for a barn too!​
/ Finally the barn. #30
Thanks for posting all the good pics; I know it takes time to do so :thumbsup:
/ Finally the barn.
Sorry for the delay in posting.
Here is the day three. Sure seems like it's taking a while, but I guess you shouldn't rush quality work. LOL
/ Finally the barn.
Day Four.. They finally started putting some siding on.
I'm starting to have a few questions about the build now.
My colors are as follows. Bright white roof, Red Siding, Bright white Wainscot, and Black Trim. On the right side they have the first wall of red siding up and no trim under the sheets to mark transition from Side to wainscot. Is this normal, because on the front there is some trim. Seems like the trim is more then just an accent but something to help direct water flow.
/ Finally the barn. #33
Thanks for the pics
/ Finally the barn. #34
LOL! There's a lot of building/work there. Boy is it looking good too.
/ Finally the barn. #35
Wedge40: Are they putting the metal roofing fasteners on the ridges or on the flats? Are they using nails or screws?
There's another thread discussing that, & I'm curious.
/ Finally the barn.
Looks like all metal is fastened using screws on the flats.
Once they got to the sheeting I didn't hear any hammers any more, just the screw guns.
Wedge
/ Finally the barn. #37
Wedge,
Congratulations on your new barn. It has a nice proportion to it. What will the floor be?
John
/ Finally the barn.
Wedge,
John
I'm doing the cardinal sin of pole building and wont be doing the floor till sometime next year. Currently the plan is 2" of packed gravel, 6mm plastic, 2" of Rigid Foam, 5" of cement with either 1/2" or 3/4" PEX.
Wedge
/ Finally the barn.
Day Five and Six.
Got the doors hung, all the windows in and almost all the siding and trim on. Had to come back today to finish siding and trim. They actually scheduled 7 days.
KUBOTA ZD1511 ZERO TURN LAWN MOWER (A65057)
KUBOTA ZD1511 ZERO...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A67737)
2024 DODGE RAM...
JOHN DEERE 4052M TRACTOR (A65057)
JOHN DEERE 4052M...
2017 CATERPILLAR 316FL EXCAVATOR (A65056)
2017 CATERPILLAR...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
