Finally pulled the trigger
/ Finally pulled the trigger
Yeah and I think some of the buckets weigh more than others. I have the square back bucket. Even if I take 1719 off the 5280 that still leaves almost 300lbs more. Might be fluids? Oh wait, I was on the tractor when I weighed it. 170lbs. That is about right.
/ Finally pulled the trigger #42
Here's a Rimguard Fill Chart that's handy to save. Answers a lot of questions regarding fill capacity of various tires. Remember, Rimguard is heavier than water. So when you do the math keep that in mind and use the appropriate number, i.e., 8.34lbs p/gallon of water.
  • Rimguard tire fill chart.pdf
/ Finally pulled the trigger #43
Interesting chart. The chart says that an R1 (ag) 17.5L-24 tire holds 55 gallons of Rimguard (assuming 75% fill). However they say to multiply the gallon figure by 80% for radial tires. Are my R4 tires radials? I have no idea. If the 80% rule applies then they hold only 44 gallons, at 10.7 lbs per gallon, or 470.8 lbs/tire, vs. ~589 for 55 gallon tires. Either way nowhere near the 800 lbs I was previously using in my calculations.
Messicks has a similar chart Liquid Tire Ballast Chart that doesn't disgintinguish between R1 and R4, it just says 55 gallons for the 17.5L-24 tires. Sounds like that's the most I can assume for added tire fill weight.
/ Finally pulled the trigger #44
I'm not sure why Rimguard says 80% for radials. No one else does.
A quick look at your tire size stamped on the sidewall will tell you if they are radial. There will be an "R" in the size designation. Reading the fine print on the sidewall will also tell you but it's easier to just read the size.
Most fill charts are for AG tires (R1). I would think there'd be a difference between R1 and R4. But I've never investigated that.
For those wanting/needing added weight, tire fluid is the cheapest way to get it.
I would NEVER use corrosive material such as Calcium Chloride.
Rimguard can create a problem if used in tubeless tires. It is slimy slick like snot. Have heard several reports of the tire coming loose from the rim and dropping out all the Rimguard because of this issue.
Cheapest is plain water if freezing isn't a problem.
Next cheapest is windshield washer fluid if freezing is an issue.
So after mowing again with the new tractor and moving some dirt, I am happy that i did not buy a smaller tractor.
/ Finally pulled the trigger #46
I am finalizing my deal on a new mx 5400 cab tractor with loader, 3rd function and 2 sets of rear remotes with all the cab upgrades that are available. it looks like a great deal. trading in my 2003 TC 45D New Holland. I will post some more info on the deal after I finalize it tomorrow or Thursday morning. Kubota has a very very good rebate going on right now on these tractors!!!
Good, let us know how you like the new tractor. The more I use mine, the more I like it.
Hope you get a good deal. What is it you want to do with the tractor?
I had a basement poured recently and they dumped the extra cement in my stone driveway. I was gonna use my grading scraper on it, but wanted to get that cement out first.
I got my loader under it and then used a sledge hammer to break it up a bit, threw it in the loader and hauled it away.
/ Finally pulled the trigger #48
Durf, would you care to share what the very good rebate deal is that's going on? Thanks!
/ Finally pulled the trigger #49
20% off MSRP with all the kubota options and everything that you want for L series and MX series along with others right now.... i'm saving 10k. I have the contract already in hand with discount, just waiting on 1 more dealer to see if they can beat my trade in allowance.. sign up to be a member of the national cutting horse association for free and you qualify for it! crazy deal!
Yikes, too late for me now.
/ Finally pulled the trigger #51
Is it safe a assume the 0% financing goes away with this in the fine print?
/ Finally pulled the trigger #53
Yeah it says as much on the kubota site. 20% off MSRP is definitely worth getting some credit union financing, though!
Kubota | Finance - Promotions & Special Offers
yes.. you will loose the 0% finance option. I have a considerable trade and some cash down so i'm only borrowing around 12k. local credit union quoted me 3.48% and that was only the 2cd call I made. will check a few others but at least for me its a no brainer to take the discount. I officially ordered my new loaded MX5400 today with my dealer and signed the contract. now I just need to wait 4-6 weeks or so to get it built. I'm pretty exited with the deal.. I was going to buy a new TYM 48 horse cab tractor but this made kubota a no brainer. my dealer gave me considerably more money for my TC 45D also which made the Kubota only about 4k more than the TYM and i'm getting more horse power.
/ Finally pulled the trigger #54
15% off MSRP is normal. So you're actually picking up an additional 5%. Have to be careful with your trade-in or they'll get that 5% back.
So,
After owning this MX5400 since this past summer/fall and getting to 50hrs, I have come to the conclusion that I really like this tractor.
I mostly have moved dirt and spread it around. I have moved snow with it as well and we had some good snow storms this year to test it. Even with the turf tires I got good traction in the snow and on the turf, except for the mud. The tractor has great power. I can lift a lot of dirt or snow at one time.
The draw backs are fuel consumption, compared to my old 25hp Ford tractor and of course the Regen.
Other than that, I am really glad I got the MX5400.
BOUROUGHS 300 GALLON SPRAYER (A64278)
BOUROUGHS 300...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
2000 INTERNATIONAL 4900 - 10 WHEELER GRAIN TRUCK (A64278)
2000 INTERNATIONAL...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
