Finally installed fire extinguisher
/ Finally installed fire extinguisher #1
davrow
Riverside, CA
Kioti CK27HST
I've been meaning to attach a fire extinguisher to the tractor for a long time. Finally remembered to buy the clamps while at the hardware store.
Here's hoping I never need it! :)
/ Finally installed fire extinguisher #2
That will work good if something on the tractor catches fire.
Hope you never need it for sure!!!!
/ Finally installed fire extinguisher #3
16 months ago a buddy's beloved Kubota B7800 suddenly caught fire in Ottawa while he was mowing. He baled off and helplessy watched it burn up. The damage was so complete, the fire officials could never determined how the fire originated!
/ Finally installed fire extinguisher #4
Looks good! Mine sits beside the seat inside of a small piece of 5" fire hose.
/ Finally installed fire extinguisher #5
I've one of my Frontier document holders attached to my right fender just to the right of where my right foot normally is. The fire extinguisher just slides into the doc holder.
Had to replace a while back. Some brush had pulled the pin, and I accidently hit the lever and discharged it.
Ralph
/ Finally installed fire extinguisher #6
Both my tractors have extinguishers mounted under the steering wheels and my round baler has a built in supression system. Always good to err on the safe side.
/ Finally installed fire extinguisher #7
Have you guys ever used "Tundra" fire extinguishers? They are not a one-use spray, they are like an aerosol that can be used whenever. I carry one in my car. They seem to be really good.
/ Finally installed fire extinguisher #10
My only suggestion is to cut up an old/cheap 'stubbie holder' (koozie?) made from foam neoprene... use strips of it as an anti-vibration barrier between the U-bolts and the ROPS.
Everything that I've added to my tractor (fire-extinguisher, light bar, side mirror) has incorporated a vibration dampening barrier of some sort.
/ Finally installed fire extinguisher #11
I have a similar extinguisher mounted in a similar manner.
One caution though!
The type extinguisher shown, with the plastic valve and handle, is the big box store type, and is notorious for breaking when you need it.
If you leave your tractor out in the sun/weather at all, the plastic will deteriorate quite rapidly.
I took all the plastic valve extinguishers I owned to the dump (I had 6), and replaced them with metal valve/handle types.
The metal valve/handle extinguishers are more expensive, but when you NEED an extinguisher, you NEED an extinguisher that you KNOW will work!
Take note: Places of business DO NOT have plastic top extinguishers!
Extinguishers sold with plastic valves/handles are homeowner garbage, made to sell for a cheap price.
/ Finally installed fire extinguisher #13
One caution though!
I'm pretty sure his has a metal handle.
/ Finally installed fire extinguisher #14
I conceal carry one all the time, everywhere I go. Except airports.
I hope I never have to use it, and I overwhelmingly likely won't, but if by some small chance I do, I'll be ready to come to the rescue!
Sure it's impractical, statistically ridiculous, and I'm more likely to hurt myself carrying it everywhere, but you can't be too safe and I don't comprehend irony. It's scary out there!
/ Finally installed fire extinguisher #15
Why do you conceal/carry a fire extinguisher?
How would you conceal/carry a fire extinguisher? ... the 'bulge' would be very conspicuous.
/ Finally installed fire extinguisher #16
I think CobyRupert's post above must have been tongue-in-cheek..
/ Finally installed fire extinguisher #17
Is that a fire extinguisher in your pocket, or are you just happy to see me?
/ Finally installed fire extinguisher #18
Perhaps... but why, then, would he explicitly exclude 'airports'? That's where extra inflammable fluids are: avgas, JP5 and the elusive (from what I've read on TBN) ethanol-free petrol.
Heck, airports even have their own Fire Brigade!
I'm boggled.
/ Finally installed fire extinguisher #19
Well played, Wagtail. :)
/ Finally installed fire extinguisher #20
Good reminder...
I've had mine on the Deere 110 for 6 years now... all I do is look at the gauge.
Every December I have extinguisher guy come to the Hospital to recertify... I will bring mine along and just pay him to do the same... dry chem.
PORTAPOTTY (A68842)
PORTAPOTTY (A68842)
x (A68191)
x (A68191)
CAT R550/D11R Ripper Teeth (8) (A68134)
CAT R550/D11R...
Shop Cart (A68134)
Shop Cart (A68134)
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
PORTA POTTY (A67714)
