Finally installed fire extinguisher
/ Finally installed fire extinguisher #21
On my JD2555 the fire extinguisher sits in a piece of pvc pipe with a cap on the bottom. Cheaper would have been to drill and put a pin through the bottom for it to sit on.
David from jax
/ Finally installed fire extinguisher #22
I think CobyRupert's post above must have been tongue-in-cheek..
You got me! I confess!
It was tongue-in-check.
I should of added "...ready to come to the rescue or protect myself".
I was giving the "standard" answers that people give as to why they conceal carry pistols. I get that people have different levels of risk, fear, probability, etc... and I don't want to get into an argument over whether their reasons are valid, or arguments that pivot on "if you need just once it's all worth it". There's many valid points to both sides.
....but when you study those arguments, how come people don't walk around strapped with fire extinguishers too?
When out in public, I've come upon a lot more situations in my life (car fires, etc..) where I've needed a fire extinguisher than a pistol.
There's been threads on TBN that show how people mount their rifles on their tractors (or chainsaws, etc...). Personally , I often find myself needing a chain more often than an AR. At the end of the day, do what you want if it makes you feel better. :drink:
/ Finally installed fire extinguisher #24
The only way to conceal/carry fire extinguisher(s) would be cargo pants, I think. You'd have to wear two, one on each thigh, to balance things out.
A fire-blanket, draped around your neck and under your shirt, would come in handy too.
/ Finally installed fire extinguisher #25
Like a cape?
Captain Extinguish to the rescue!!! :D
/ Finally installed fire extinguisher #26
Inspired by this thread, I mounted one on my ROPS.
enhance
/ Finally installed fire extinguisher #27
Vehicle mount on Kubota B26. Good protection from limbs. Same mount and placement on M59.
/ Finally installed fire extinguisher #28
enhance
Can't quite tell from the picture, but if that is a plastic valve/handle type extinguisher, they are homeowner units that are built to meet a price point, and are generally considered unreliable because of the plastic valve/handle components.
/ Finally installed fire extinguisher #29
Interesting thread. I was at my doctors today for my annual physical and we always end up chatting about something other than medical .. by the way he said I was in great health except for many joints. Like and old car motor and tranny are great but tires are flat and fenders falling off. Anyway he mentioned that he had a tractor fire and it totaled the tractor. I asked did he have a fire bottle, the answer was no. I suggested he get one for the new tractor and maybe two. on my RTV and tractor I keep a dry chemical bottle AND a Halon/ Halatorn bottle. The reason these last two, whichever you get will quickly put out a fire on a vehicle and live no residue nor harm electrics. Dry chemical I use for brush etc
/ Finally installed fire extinguisher #30
"Dry chemical I use for brush" ???
Brush is a Class A fire?
Why not just plain H2O for brush?
/ Finally installed fire extinguisher #32
Hey give him a break...he's from South Texas water is scarce and expensive down there.:D
"water is scarce".....
Spoken by a guy who obviously has a LOT of experience with water.
/ Finally installed fire extinguisher #33
CG approved marine model. Handles are metal.
/ Finally installed fire extinguisher #34
enhance
What is that pull button by the extinguisher? Is that some sort of quick release? If so, where did you get the mount? That seems like a good idea to get it off faster, because if something catches fire on a tractor you'd have to be quick to get the extinguisher off something on fire itself!
I've been thinking about mounting one in my Kubota L6060 cab. I haven't figured out a good place to put the mount so I haven't done it yet. I looked for examples a few months ago and didn't see any good ideas for inside a cab. I can't just sit one in there because everything bounces around so much. My luck the thing would discharge with me in the cab, lol.
Matt
/ Finally installed fire extinguisher #35
Now you just need to take a hole saw and drill holes in your various plastic panels so you can actually allow the fire extinguisher to get at a given fire.
/ Finally installed fire extinguisher #36
TnAndy's mount looks like one of these: FIRE EXTINGUISHER MOUNT BLACKFIREX-MNT-DAG
There's tons of clones on Amazon etc. Looks like a nice design. I think I'll get one for the tractor and one for the UTV.
Also, that looks like a drafting machine in TnAndys photo. I haven't seen one in quite a while.
/ Finally installed fire extinguisher #37
Extinguisher mount: Amazon item = $28.69
/ Finally installed fire extinguisher #38
Yep...Amazon has a bunch of knock off versions. Comes with hose clamps to strap it around something like the roll bar, or has holes you can mount with self tapping screws to something if you prefer to go that route. Simple pull of the red knob releases the extinguisher and it holds it very securely with the knob engaged.
The drafting machine is leftover from my days teaching high school industrial arts. They were tossing them in the dumpster while changing over to CAD....I "rescued" that one and brought it home with me and have it set up on a board in my shop office.
/ Finally installed fire extinguisher #39
Vehicle mount from Amazon. Nice heavy steel made for easy mounting.
Kidde 408-368064 Fire Extinguisher Bracket, 5 lb. https://www.amazon.com/dp/B00N4ZZBYI/ref=cm_sw_r_cp_api_i_xkFdEbKN3QV39
For a 5# fire extinguisher.
Installed with 3 square U-bolts. No drilling or cutting. Made rubber washers to back pull pin and clamp to make rattle free. Survived multiple tree limbs and bush hogging.
/ Finally installed fire extinguisher #40
Just bought another vehicle mount for a 5# fire extinguisher to upgrade the camper. $21.52 delivered from amazon. Adjustable to get a tight fit. Sturdy steel construction. Prices vary so watched till it dropped. These work well on my two tractors that see hard use.
