Finally got the 7060 home
/ Finally got the 7060 home #61
My buddy’s M7060 is a fine unit but the front axle & loader isn’t near the size of my JD 5k series 4cyl.
Not knocking it at all. He Loves it :D
Going to add some small Bluetooth speakers somewhere in the canopy. Gotta have some tunes while I’m working, and the wife didn’t think I needed a cab tractor so I’ll improvise!
/ Finally got the 7060 home #63
My buddy痴 M7060 is a fine unit but the front axle & loader isn稚 near the size of my JD 5k series 4cyl.
Mr Dog-- your Deere's are over 2000 lbs heavier than his M7060 and i'd think the loaders would thus be heavier. Just based on appearance, the Kubota loaders look stronger to me than other brands at a given weight/size. And seem conservatively rated as well. His 7060 also has bevel gear steering FWD with a lot better maneuvering than your Deeres and better than my Massey Ferguson 2660. Not sure what the 4cyl means in the context of the talking, but his 7060 is a 4cyl engine too as are your Deere and my Massey.
/ Finally got the 7060 home #64
The 3cyl JD 5k (5045-5075) series has much smaller axle than my 4cyl 5k series.
Your right on the Kubota frt axle turning deep :thumbsup:
I used his M7060 & LP RCF3696 today & kept disengaging the PTO resting my arm on fender as I have for many years :mad:
/ Finally got the 7060 home #65
I used his M7060 today & kept disengaging the PTO resting my arm on fender as I have for many years :mad:
M
Do you have arm rests on your seat that could be used? I've seen users fold them up and forget to fold them back down. :D
/ Finally got the 7060 home #66
You might want to consider just getting a set of good quality headphones instead. Mine is a cab unit and even so the stereo has to be turned up really loud to be heard over the sound of the engine and implement. That's what I'm thinking of doing - put on a set of headphones that will not only allow me to listen to music at a reasonable level but also attentuate the roar of the engine.
/ Finally got the 7060 home #67
Deserteagle is Right :D listen to this wise man.
I’m so much more relaxed after 3-5hrs of mowing on Zero or Bush Hogging on Tractor.
Plus it saves your hearing as I’m cutting grass 10hrs a week.
I do have armrests, but the issue is that its so steep that you are literally holding yourself up with your arm on the fender and grabbing the handle. My arm is no where near the arm rest on the seat at that point. I'm sure with time I will get used to it and pay more attention to it. At least that is the issue I have, and I assume that it may be the same for Brown Dog.
I already have a great set of ear buds. I don't mind wearing them when I am mowing but I definitely don't like them when I was pulling trees. Just to much happening that I want to be able to hear. I have some leftover wakeboard enclosures that previously were mounted on my side by side that I am going to mount up high by the ROPS this weekend. I bought a small marine amp to power them that I should be able mount behind the seat and take up very little room. I can run a 3.5mm to rca cord directly to it and listen to Pandora via my phone. Should be an easy install. I'll post some pics after I get it installed.
On a side note these should have the potential to be very loud! The wife is already concerned what the neighbors might think with me boomin across the pasture. lol
/ Finally got the 7060 home #70
I bike, drive tractor, and at times walk or run a boat. In ALL cases I consider headphones a major safety issue and a cause of accidents and near-disasters. Seen 100 examples. There is no benefit that justifies giving up your ability to hear and react when operating equipment in my view.
/ Finally got the 7060 home #71
I wore ear muffs while operating my L2501. Had too. That thing was too loud for my comfort.
/ Finally got the 7060 home #72
... My arm is no where near the arm rest on the seat ...I assume that it may be the same for Brown Dog.
It is :mad:
/ Finally got the 7060 home #73
I totally agree with this.
I only wear headphones mowing my stump & rock free tame ground that I’ve mowed for 23yrs.
I know every square foot of it well.
I don’t wear them Bush Hogging my steep banks or unfamiliar ground.
I hate to see people driving vehicles on the road wearing earphones.
/ Finally got the 7060 home #74
You can add me to the list of people who agree with you!
Always wonder what the repair cost is, with and without ear buds. Catch a noise sooner is often cheaper to fix!
David from jax
/ Finally got the 7060 home #75
David from jax
I hope the ones that are scared of ear buds still wear ear plugs or muffs. Because hearing damage is real and not reversible ... unlike the belt or gearbox you MAY be able to save because you THINK you can hear it sooner if something goes wrong..
/ Finally got the 7060 home #76
I hope the ones that are scared of ear buds still wear ear plugs or muffs. Because hearing damage is real and universalize... unlike the belt or gearbox you MAY be able to save because you THINK you can hear it sooner if something goes wrong..
I'm not sure what is being discussed here but ear protection is a must or your hearing will definitely be irreversibly damaged. I wear ear protection when I'm on the tractor, zero turn, AND operating a chain saw.
/ Finally got the 7060 home #79
Well said JWR
I totally agree :thumbsup:
This new younger generation era & Engineer caliber guys has a totally different approach than us old sChOOL hands on guys lol
/ Finally got the 7060 home #80
Guess I've worked as a miner for too long...unless you work inside an office, the following applies:
Steel toe boots - mandatory
safety glasses - mandatory
hi-vis jacket/vest - mandatory
ear plugs - mandatory
gloves - mandatory
And those are Federal (MSHA) regulations, not because the mines want to spend money on safety items.
I never get on my John Deere without wearing ear plugs - the roar of the engine makes my ears ring otherwise. Same with chainsaw, lawnmower, etc.
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
20' CONNEX BOX (A65643)
20' CONNEX BOX...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
3pt Countyline Auger w/Bit (A64126)
3pt Countyline...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
