finally got my
/ finally got my #1
swnoel
New Hampshire
Kioti DK35
DK35 with BH and Loader...
Been playing with it and was wondering if there's any trick into getting the front wheels in and out of engagement?
/ finally got my #2
The floor mount lever is sticky . Keep pressure on it as you go into and out of forward and reverse to help unbind things.
/ finally got my #3
I have a DK45. The lever is actually backwards to what the manual says. Down for 4wd and up for 2wd. Some times it likes to stay in 4. If I go to H range and try going forward then back it sometimes helps it slip out. When I have difficulty taking it out I usually just forget about it for a while then try it later on and it usually works.
Good luck.
/ finally got my #4
Like Nelson mentioned.
The manual is wrong.2 WD is up 4 WD is down.
I find I can engage 4 WD more easily if I keep the tractor rolling with little to no load (slides right in).
To disengage I just pull up on the handle while moving.(I don't even slow down or bother with the clutch to take out of 4 WD).
/ finally got my #5
Forgot to mention.
Congratulation on the new tractor and good luck.
Where are the details?
What loader did you get?
What backhoe?
/ finally got my #6
That was a couple good points, Vince. I realized after reading your post that I have done it that way too and it works good. /forums/images/graemlins/smirk.gif
/ finally got my
1450 loader and KB2385 BH
Finally got it in and out of 4wd
thanks
/ finally got my #8
</font><font color="blue" class="small">( Finally got it in and out of 4 WD )</font>
Thats good ! /forums/images/graemlins/cool.gif
Did it help any to keep the tractor moving a little ?
After some use it should loosen up some.
/ finally got my #9
</font><font color="blue" class="small">( 1450 loader and KB2385 BH )</font>
Do you know if the 2385 is the same backhoe as the older #2085 or are these completely differant hoes ?
I do know the 2085 is the same hoe as my Rhino 85.
/ finally got my
I don't know whether it's the same hoe
I just put a little more elbow to the shifter and it went in.
/ finally got my #11
another trick for getting it out of 4wd (if you have a loader) is just lift the front wheels off the ground with the loader then it should easily slip out of 4wd.
2010 BMW 128i Convertible Coupe. (A61574)
2010 BMW 128i...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2012 Gastron 18ft Boat w 18ft S/A Boat Trailer. (A61574)
2012 Gastron 18ft...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
