Finally built a laser grading rig using my box blade.
   / Finally built a laser grading rig using my box blade.
I noticed your control box in your tractor is up overhead.
Mine is mounted on my door handle on my right side. I find myself resting my right hand on the control box, and using the switches constantly.
I will switch to 'manual' to 'auto' constantly. This is mainly because when I hit a high area, my blade wants to go down and the wheels keep raising up until they can't anymore and my hydraulic system gets in a bind.
I also will switch to manual when I'm driving with an empty blade for another load. I feel that this helps keep the valves from operating more than necessary, therefor adding to it's lifespan and keeping the oil from overheating.
I have an outboard knob with a switch for auto/manual operation. It is currently just to the right of the control panel. Just have not had time yet to pick a good mounting spot for it. It has about 10 ft. of wire on it so it will fit somewhere.
My hydraulics can be set to a time limited response, so after the cylinders have had enough time to cycle it will shut off to prevent dead heading the pump. I still need to get a better handle of all the built in functions.
The black knob is over the rear view mirror inside the cab.
   / Finally built a laser grading rig using my box blade. #22
Can you explain a bit about how the slope is set with the laser? For instance, if you wanted level north to south and then a defined slope east to west or somewhere in between, how is the transmitter set to accomplish that?
What are the advantages and disadvantages of laser verses GPS for finish grading?
May I ask approximate cost of you laser system and hydraulic valve(s)?
Are the hydraulic used in the systems normally closed or open center?
Thanks for posting. Very interesting!
That is slick! But... it wasn't quite clear to me exactly you are trying to accomplish with that setup? Are you working to just level off a large area? Or maybe giving it an exact slope? What is the area to be used for?
The fields in my locale are flood irrigated so the ground needs to be accurately graded to allow the water to cover it evenly. How much slope is determined by NRCS engineers. I work off their recommendations.
Water on the field will quickly show where corrections are needed. Any islands will result in barren land or weeds. Ponding or low spots are also problematic so you need the proper grade for an even flow to water correctly.
With machine control the hydraulics can approach 1millimeter accuracy. I will be very happy with +/- 1/2 inch for field work. NRCS specs call for +/- 1/10th of a foot, or about +/- 1.25 inches.
   / Finally built a laser grading rig using my box blade. #24
Steve,
I know you've been thinking about doing this project for a long time now, and it looks like the planning paid off. Great work on the prototype!
When you mentioned building a fold down tongue for it, did you mean that you would eventually use it as a tow behind for grading? Or did you mean you'd just tow it from place to place? I was confused by that, and I have this strange belief in my head that it would work better if setup as a tow behind unit, rather than 3 point hitch mounted, however I have no basis or credibility for this belief, just wondering your thoughts as well?
What do you figure it weighs now with the added steel?
Again, great work on this project, I'm sure it will be a good return on investment for you.
The laser has an X axis and a y axis you can set either one to level or enter the slope you want to three decimal places. You do have to align the laser properly to get good results. I will mark the spot for the laser tripod and use a target to aim for to get repeatable alignment.
Laser systems work well for flat work that I do. Cheaper than GPS systems too. GPS systems work well and add a third axis the way to go for more intricate work.
My laser is a Topcon RL 200 2 slope with remote and simple receiver cost $3850 with rechargeable batteries.
The receivers are Topcon ls b110w and ls b110 the w model has a remote display the other does not. The two receivers were about $3000 combined wish the remotes being an additional cost.
The control head is used and was $1600 a new one is about $4000. Topcon system five 9164 004
The valve two spool is a Danfoss PVG 32 proportional control so that it can feather or vary the flow as needed. This valve was about $1800 but the time spent researching the valves was more costly.
Cables were costly about $2800 but no way around them that I could see.
You can have either an open or closed system.
Steve,
My plan is to be able to tow it with my pickup to the jobs AND tow in the fields for fine finish work. When the tongue I locked in the raised position it will have a quick hitch mounting too. The biggest pain using the Gannon is it is the only implement I have that is not quick hitch compatible.
I estimate it weighs about 1750 lbs now, really haven't added it up yet. The tires and aluminum wheels are for a corvette with 275 40 17 tires but that was the best fit. At least I don't have speed rating concerns.
Tow type vs. 3 point same as a brush mower you can back up into spots and quickly clean out a corner. The hitch or rockshaft is fully lowered and can float up and down. So the tractor does not cause much of a problem with the blade. If I need to get gnatsazz close then tow it.
   / Finally built a laser grading rig using my box blade. #27
I appreciate your taking time to provide all this information. Certainly not an inexpensive project.
I modified a Landpride box blade as others have done by adding a hydraulic rockshaft to the rear but just pivot mounted and no parallel linkage and caster. The wheels are fairly close to the back of the box blade so no caster is needed even in 3PH mode. Your independent twin lift control sure adds a lot of capability to the package.
I used similar logic in determining the pros and cons of 3PH mounted versus tongue pulled and made a pin-on tongue so it could be used either way. Your flip-up tongue is more convenient and adds more weight for downforce when folded for 3PH use.
Would love to have the laser control but probably not going to happen with my hobby budget. :)
   / Finally built a laser grading rig using my box blade. #28
I took a 3pt box blade and added wheels and a tongue that pinned in place using the 3pt mounts, worked out real nice.
   / Finally built a laser grading rig using my box blade. #29
I ran across this design also, if I was going to use it both ways much I’d do it this way, simply raise it and you have your 3 pt. IMG_0122.JPGIMG_0123.JPG
   / Finally built a laser grading rig using my box blade. #30
Very impressive Steve. Thank you for all the detailed answers to all the questions. You have made quite a commitment but if you are expecting +/- 1/2" that would seem to make it all worthwhile with the irrigation requirements you are dealing with. Thanks for sharing.
gg
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2017 John Deere HPX 4x4 Gator Utility Cart (A56857)
2017 John Deere...
LOT OF RIDGE ROW TIN (A58374)
LOT OF RIDGE ROW...
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
8' X 42" X 10' PALLET RACKING (A58374)
8' X 42" X 10'...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
