Filling a ditch/valley
/ Filling a ditch/valley #1
future_vision
New England
DK6010SE HSA
I have a piece of rolling land and I am at a point where I am considering filling a low point on the land (pictures below). What I am trying to determine is what is best to fill it with. I have a variety of materials handy. Everything from dirty fill(loam, twigs, small rocks, roots), to regular loam to a sand loam mix etc. The dirty fill is by far the largest amount of material I have but my concern is if it gets saturated it will be undriveable with my 60hp tractor. What would you use? I'm including images of the materials I have as well.
/ Filling a ditch/valley #3
The question is why is that low spot there? When it rains does it flow a lot of water? If it does anything you put in there may erode away. Filling it in and adding some rip rap where the water would speed up would work.
/ Filling a ditch/valley #4
I have a bunch of areas that I've filled and that I'm still filling on my land. For the smaller ditches caused by erosion, I put in rock, busted up concrete and bricks to stop the erosion and catch the dirt. Over the years I've forgotten where those areas are after the grass grew in.
For the bigger areas I fill them with the ash from my burn pile. I try to clean up my burn pile once a year. The Ash seems to be mixed with a bunch of dirt which is always a mystery for me since I pick up all the branches and debris with a grapple, but after a year, it's a huge pile of dirt and ash mixed together. I have a one-yard bucket on my backhoe, and it can take 20 to 30 loads to clean it all up. I've been working on a very big area for years now. I'm probably halfway there. This area is close to the property line and the fence. I can't mow along the fence in this area with my batwing, but in the area that I have filled it, I can. Once I get the ditch about a foot from being full, and I've driven over it so many times that it's compacted, I add dirt to create the top layer so grass will grow there.
It does collect some water but that area also slopes toward the back of the property so the water doesn't hang out. Even after we bring up the grade it'll still slope towards the back
Does that compact well? How does driving on it work out? My concern would be creating a bog with so much organic material.
/ Filling a ditch/valley #8
When I spread the ash/dirt mix from my burn pile, I back drag it with my bucket, and then when I come back with another full bucket, I drive over it with my front tires. The tires will sink several inches into the loose soil until it's all compacted, then it's solid. I just do this with every load, and when I'm done, it's all very solid.
After the grass grows in, I can't remember where these fill areas are. I mow over them with my cab tractor and batwing without leaving any ruts or sign that I filled in an area. The one I'm working on now is probably 1,000 feet long and I'm almost halfway filling it in. Where it's done, it looks great. Where I'm working, it's ugly, but will eventually get there and look great too.
Good to hear. I'm running a Kioti DK6010SE with filled tires so we're looking at ~5000 lbs I believe.
/ Filling a ditch/valley #10
Our 911 service provides an alternate number to call in advance of starting slash pile or controlled burns.
I found that out - after - someone across the lake, over a mile away reported smoke after one of our initial burn piles was torched.
The local volunteer fire department sirens blaired and I looked at my wife and said "...They're coming for us!..."
They were friendly!
/ Filling a ditch/valley #11
They were friendly!
Same here.
Neighbor called in thinking our barn was on fire. FD said it was OK, a controlled burn. I have since given that neighbor our phone number.
/ Filling a ditch/valley #12
I did the same thing as Eddie when clearing land here, but only a small area 50x80' low area that water would pool after heavy rain. I filled in with dirt, rocks, roots much like you have about a foot thick then had a few loads of sandy fill dirt spread on top of that then loam and grass.
Now I run over with my tractor 4000Lbs and don't sink in even with a load in the bucket. The amount of sticks and roots tend to bind together is my experience.
/ Filling a ditch/valley #13
Its your 100% sure this area is just going to be grass, problem one helps solve problem two. Dump your tree debris, fill over that with the nastier material and top with the sand/clean fill.
Thats assuming you are 100% sure it won't ever be a structure, septic tank, driveway, or well.
/ Filling a ditch/valley #14
Just understand that the area may need redressed a bit in 5 years or so, my just adding some additonal clean fill if areas do settle
/ Filling a ditch/valley #15
In my early years, when I first bought my land, I didn't realize the importance of compacting a fill area right away. In this case, which happened twice, I dug out a stump and then put the dirt back in. I added a bucket of dirt to top it off and smoothed it out.
A year or so later, after multiple storms and lots of grass growing over it, I drove over that area with my backhoe and sunk into it like quicksand!!!
I learned that when soil isn't compacted, it holds water for a very long time and remains Very, VERY soft just below the surface!!!!!
/ Filling a ditch/valley #16
Im betting you get some small stumps in the burn mix + some other incidentally pushed around in dirt. They add up. Sounds like you burn a LOT.
/ Filling a ditch/valley #17
They were friendly!
In Nevada it is mandatory to call Sheriff's Dispatch (not 911) in advance of doing any burning, and report your name and address. You also have to call to let them know when you are done burning. If you don't, and someone sees the smoke and calls out the fire department, it will cost you!
/ Filling a ditch/valley #18
put a ad in the paper for free dumping for concrete,it's a clean fill
/ Filling a ditch/valley #19
A few points:
-fill needs to be compacted typically more than you think.
-Do your fill in layers with compaction following each layer keep layers at a modest thickness 6” or so per layer
-limit the amount of limbs and other woody material in your fill, these will break down over time and result i either collapse of your fill or voids in your fill
-avoid large rocks or concrete chunks in your fill as these can create voids and later collapse
- I like to start any fill of more than several inches with a good layer of gravel (crushed concrete works also) 4” if possible, this is for drainage. Again loom is fine for next level of fill, just not lots of wood stuff in it. The several inches of clean dirt for the final fill material. Then seed the area
/ Filling a ditch/valley #20
Just remember that the more organic material (wood, grass, etc) the more it will settle as that stuff rots away.
New/Unused Pallet of 8 Binders and 16 Chains (A61166)
New/Unused Pallet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 Ford Econoline Box Van, VIN # 1FDWE3FN3MDC22817 (A61165)
2021 Ford...
Flatbed Truck (A55973)
