Filled tire problem
/ Filled tire problem #21
I read a story in "Green Magazine" about early testing of Deere's giant of the 70's, the 6030. It was factory rated at 175HP, but most 6030's would spin a dyno at well over 225 HP. They were weighted down with all the ballast possible, and still had a hard time finding enough traction. When they did bite, sometimes the tires would grip the ground better than they gripped the rims. A Deere engineer who was also a drag racer solved the problems on their test tractor.
Screws through the rim and into the bead area of the tire.
I can't imagine an inflated tire staying "rimmed up" on the bead while slipping. ESPECIALLY a tubeless tire.
/ Filled tire problem #22
/ Filled tire problem #23
without knowing what kind of tractor you have this is hard to
imagine. Are you sure the rim turn in the tire? mark the wheel and rim with chalk,crayon, white out or what ever and try and recreate problem. Could your 2 piece rim actualy be slipping instead? the odds of rim slipping and tire not leaking have to be very slim. have someone else drve tractor so you can see whats happening. Possibly chain drawbar to a tree and slowly tighten slack and see what slips.
/ Filled tire problem #24
/ Filled tire problem #25
I'm going to say the tube is too small. If you installed fluid without a tube, then that is your problem.
/ Filled tire problem #26
/ Filled tire problem #27
I just love some of these post /forums/images/graemlins/grin.gif
I will say your Kioti has too much horsepower and needs to be derated for the tire/rim combination /forums/images/graemlins/tongue.gif
No really it sounds like the rim guard is between the rim and tire causing the slippage. I see two fixes.
1. Dismount tire, clean rimguard off rim/tire and add tubes to hold fluid only. This will keep fluid off rim/tire.
2. Add bead locks.... I would not do this one on a tractor.
/ Filled tire problem #28
/ Filled tire problem #29
You need to take that supercharger off and turn the fuel down. Your making too much power..... Couldn't resist. That's an old drag racing problem with slicks. We actually ran screws into the beads to cure it. Never heard of it on a tractor but I have no doubt your observation on the lubrication is the likely culprit. Curious to see the replies on this one.
/ Filled tire problem #30
/ Filled tire problem #31
I should read the entire thread first. Was I second or fourth on that? /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
/ Filled tire problem #32
problem solved. the rim guard got betwen the tire and the beed causing it to slip. only dealer round here that could do it was the kubota dealer. got to looking at them and traded the kioti. Took a bath on the loss, but got a new tractor with a new waranti. they gave me 40% of what i paid for the kioti last year. /forums/images/graemlins/frown.gif checked wit the nh dealer and he wouldnt take it in trade at all. wif is pood
/ Filled tire problem #35
</font><font color="blue" class="small">( problem solved. the rim guard got between the tire and the bead causing it to slip. only dealer round here that could do it was the kubota dealer. got to looking at them and traded the kioti. Took a bath on the loss, but got a new tractor with a new waranti. they gave me 40% of what i paid for the kioti last year. /forums/images/graemlins/frown.gif checked wit the nh dealer and he wouldnt take it in trade at all. wif is pood )</font>
GEEZ Sorry but I think you made a very stupid move there on a wet slipping tire rim. $50 or less fix. Hope that cold shower felt good.
Randy
/ Filled tire problem #36
Randy
/ Filled tire problem #37
Randy maybe it true after all. Some folks have money to burn. /forums/images/graemlins/wink.gif
/ Filled tire problem #38
/ Filled tire problem #39
</font><font color="blue" class="small">( traded the kioti. Took a bath on the loss, but got a new tractor with a new waranti. they gave me 40% of what i paid for the kioti last year. )</font>
/forums/images/graemlins/ooo.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/confused.gif
OMG.. you got took.. 40% of value at a year old!! I traded my 1997 NH 1920 in 2004 for 90+% of what I paid for it.. back to the dealer I bought it from...
Man oh man...that's a horrible deal..
Soundguy
/ Filled tire problem #40
Soundguy
iDrive TDS-2010H...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
Caterpillar 302.5C Mini Excavator (A61572)
Caterpillar 302.5C...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
Kubota M8200 Tractor (A64047)
Kubota M8200...
2017 CAT 926M WHEEL LOADER (A63569)
2017 CAT 926M...
