Ferguson TO-35
/ Ferguson TO-35 #1
ArcherXC
Swansea, SC
1965 Massey Ferguson 135
Are Ferguson TO-35 good tractors? I have found a good looking little Ferguson. I will mainly need it for light work and hooking up a bush hog. Are parts hard to find?
Thanks!
/ Ferguson TO-35 #2
Few questions....Is is gas or diesel? Is it a "Delux TO-35"?...reason is if its a Delux it has a two stage clutch (this is a good thing)...if its a gas engine its a Z134 Continental...parts are readily available for this tractor....NOW...if its a diesel, it is a 4 cyl "Standard" diesel...these may be harder to find parts for....suggest you go to tractordata.com and look this up....lots of info..also go down the forums below to the Massey Ferg. stuff...mucho help down there... good luck. BobG in VA
/ Ferguson TO-35 #3
They are great tractors. They have a fair share of power for their size. Parts are easy and usually cheap to get.
/ Ferguson TO-35 #4
ditto to the other posters genral questions.
also.. what cond are tires and overall machine in.. what are they asking.
post back
/ Ferguson TO-35
The machine looks good. It has been taken care of. The engine smokes a little and the steering has significant play in it but it is in good condition. He wants $3000.
/ Ferguson TO-35 #6
hm.. smokes and loosey goosey steering.. i'd want to have plenty less than 3K$ in it at the start.
/ Ferguson TO-35 #7
i had a TO 35 w/std 4cyd diesel for 28 yrs. purchased w/engine rebuild for 3k in '78. good solid tractor, yes, had to have steering worked on & it was smoking when i traded it in (for $1800 credit). the std. diesel is hard starting. sometimes used either but of course beware of that. and yes, parts for that engine will continue to be hard to find, probably through salvage. so my guess is iffy, try to talk down, you could be out that much trying to get it up to speed. good luck
/ Ferguson TO-35 #8
also, the successor to the TO (also massey 35 or maybe 135) used a 3 cyl Perkins engine, more reliable...otherwise tractor is the same. shop around
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
New Holland 3930 (A60462)
New Holland 3930...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
