Fencing options
/ Fencing options #1
northcaroliney
Searching
Planning to kick off a fencing project of around 3000' - any recommendations on whether to pursue pounding posts vs. pre-drill a small diameter auger hole (4") and use bucket to push the posts down. This latter method seems less technical and I've heard of success around here in our predominantly clay soil. Thoughts or recommendations?
/ Fencing options #2
Bucket all day long, no question. Enough said.
That is how we do it here in Nebraska in the sand dirt and clay, we will see how it works at our place in Montana with all the rock though.
/ Fencing options #3
Stoney Ridge Farmer on You Tube has fencing videos. Most of his are pounded by different methods I believe.
/ Fencing options #4
My neighbor just put in 7000ft fence, contractor used a hydraulic post driver which went very well and seemed easy.
/ Fencing options #5
I am in heavy black clay and drill and then set the post in concrete.
IF you are going to drill, then push them in with a bucket, the biggest issue is keeping the hole straight. I can't drill a straight hole with my 3pt PHD to save my life. I upgraded to a 12" auger bit for 6" posts so I would at least have a chance of getting the post straight and in line.
Good luck.
/ Fencing options #6
I was wondering if the OP could rent a hydraulic post driver locally for 3000ft of fence. For horses I drilled for an 8"-9" post every 50 ft, then 4 x 7ft T posts between. Woven wire. Danuser auger worked well, tamped in straight. Wire up 8" so easy to mow, insulator with white ribbon electric on top. Horses.
/ Fencing options
Thanks for the thoughts. 3pt auger and straightness was one concern... for project of that size, I could also explore just renting a skidsteer to auger/push in vs. renting a pounder pounder for the tractor. I've looked for rental post pounders in my area though and they're hard to come by - I was only able to find one option that was about 1.5 hrs away and usually very in demand/booked out.
/ Fencing options #8
Where are you located? Having drilled holes and pushing the posts in, drilled holes and packing them in with dirt, drilled holes and using concrete to set posts and using a hydraulic post driver I will by far go with my post driver for its speed and how solid the post is.
On clay it will work best with natural moisture in the soil softening it up. It will put them in very solid, in the right dirt I have timed myself from the time I stepped off the tractor, drove the post, and got back on the tractor I was right around 2 minutes. This was an 8" post and was in the ground 40".
/ Fencing options #11
I just had about 700 ft of wire fence put in and the guy pounded all of his poles. 6" diameter, 8 ft long pounded to 5 ft. Solid as a rock when he was done. We used Tornado wire, nice stuff.
/ Fencing options #12
If you get frost in the ground where you live, you have to pound them in, otherwise they will pop right out the next spring. Even using concrete they will pop right out, and actually worse so because now the frost has something to grab hold of as it pushes upwards.
I do all my fencing in the spring of the year. I use a bulldozer, but a rented excavator will also pound them in.
I would use nothing but pressure treated posts and woven wire fence just because it is so cheap. It might take 3 days to put up 3000 feet, but what the heck, 30 years from now it is still up, and no having to maintain juice on those 3000 feet at all. What Pressure Treated wooden posts and woven wire costs...divided over 30 years, makes it the cheapest fence by a LONG shot.
/ Fencing options #13
/ Fencing options #14
I don't think you have given enough information to answer your question properly. What kind of posts are you putting in? Metal? wood? Round wood? what diameter? 4 X 6's? Each of those variables may have a different answer. I just put in about that much fence, I used metal "t" posts with an inexpensive gas powered pounder. Worked great. I used railroad ties for H-frames to pull barb wire against and used an auger on the back of my tractor to sink those. In our area, installing any fence in the spring is a lot easier than in the summer when the ground is dry and hard.
(3) 11/29-15 Hoosier Dirt Track Tires (1) 29/11-15 American Racer Dirt Track Tire (A64127)
(3) 11/29-15...
2018 Ford Explorer SUV (A64557)
2018 Ford Explorer...
AGI Westfield WRX 8-61 (A64126)
AGI Westfield WRX...
6x12 Leonard Utility Trailer (A65579)
6x12 Leonard...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
