FEL Snowplow
/ FEL Snowplow
I pretty much finished it today, Blew off work-there's tractor stuff to do /forums/images/graemlins/wink.gif
Back home now for final assembly, the cylinder's and trip springs are attached.
/ FEL Snowplow
The mouldboard is mounted temporarly so it can be marked for cutting.
/ FEL Snowplow
The mouldboard is cut and attached, and so is the cutting edge.
/ FEL Snowplow
Skid shoes installed and set for 1/2" of blade clearence.
/ FEL Snowplow
The plumbing is completed, I added adjustable in-line flow restricters because the plow was moving way to fast at full throttle.
/ FEL Snowplow
Side view of plumbing...
/ FEL Snowplow
And here is a view of the whole setup, ready for snow...
/ FEL Snowplow
Last view...
It is 62* out and cloudy, no snow this week...
/ FEL Snowplow #29
Nice job Kenney. If you were closer we would let you try it out on our drive (once we get more snow that is).
What did you use to cut all that steel, a chopsaw?
/ FEL Snowplow
WinchMan,
I am going to try this picture again, It is of the JD FEL Plow on a 4710 tractor with a 460 FEL...
Here goes /forums/images/graemlins/confused.gif
/ FEL Snowplow
Thank again Mike,
A chopsaw did most of the cutting, And a Miller 375 plasma cutter also did some.
If I get to Ohio, I will look you up for sure! /forums/images/graemlins/laugh.gif
/ FEL Snowplow #32
hi kenny, great project. please give me some info on the adjustable in-line flow restricters that you used. where to buy them? price? my jd74 front blade also angles way to fast at any engine speed above an idle. i'm also in md wondering if it will ever snow so i can try it out. thanks in advance. bud
/ FEL Snowplow #33
Again, great job ... Next project ... heated cab? /forums/images/graemlins/grin.gif
/ FEL Snowplow #35
Ken
Nice setup. /forums/images/graemlins/cool.gif
Just one note: The flow controls look like ones designed for pneumatic (air) systems. They may work OK. But brass will not hold up to the loads that hydraulics put out.
/ FEL Snowplow #36
hi mike, thanks for answering my question but when i hit your "click here" all i get is some sort of microsoft error. can you be more specific? thanks bud
/ FEL Snowplow #38
Just a suggestion.Weld a pivot bracket on the top of the plow and the mounting bracket.Then run a bar between the two that you can drop pins into.This will lock it rigid and you can use as a grader blade
/ FEL Snowplow
</font><font color="blue" class="small">( The flow controls look like ones designed for pneumatic (air) systems. They may work OK. But brass will not hold up to the loads that hydraulics put out. )</font>
Thanks Ron,
I was not aware of that, I am very new to hydraulics, I bought these on EBAY for $5.00 Each, they were listed for use with hydraulics so I bought them.
I will get some steel ones from the surplus center next time I place an order, But these will work for now!
/ FEL Snowplow
Good Idea Tevi, I had not thought of that. For now I can just use the bucket though...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A59914)
2016 FORD TRANSIT...
Location Tampa, FL (A61567)
Location Tampa, FL...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
