FEL Reinforcement
/ FEL Reinforcement #1
Slackdaddy
Land of the Free
Kioti CK20HST
I have noticed on a few brands of CUT's, the FEL has a Reinforcement from the pivot point down to the front "bumper" area. This looks way stronger than the ones with just a steel "tower" running strait down and bolted to the frame with no "trianglation"
Am I correct that the ones with the "extra" bracing from the pivot to the front bumper are more durable ?
What brands of 28-35 HP Cuts have this heavy duty FEL with bracing ?
Are there any CUT's with FEL's that are more "Permanent ", for serious dirt work ? I will be selling My Case 580 loader and getting a CUT, but do not want a toy loader, I do not mind a small loader, I just want a real one.
Thanks,
Nick
/ FEL Reinforcement #2
I believe if you do a search you will find quite a detailed description of FEL buckets that was done by a Mr. Bob Skurka. He documented in detail the differences between heavy duty buckets, and standard buckets. :)
/ FEL Reinforcement #3
without a doubt a cross member running from the top of the tower to the front frame stiffens the whole construct. it counters rotation at the frame mounting points of the arms when lifting and in addition when slamming into a pile, etc counteracts the opposite rotational force at the same point. to build it without this piece, bigger bolts, more frame contact, stronger arms etc must be used. some of the quick detaches have the additional front stabilization, others don稚. I went for my 300cx loader for the above reason. the front cross member doubles as the unit kickstand when detaching but sits on the front frame to counteract rotation when loading, and locks into the bottom of the front frame for preventing rotation when hitting something with the bucket.
/ FEL Reinforcement
IH3444,
Cant find Skurka's posting on fells,
any idea how long ago ?
Thanks,
Nick
/ FEL Reinforcement #6
Don't fall into the pit of armchair engineering. All of these loaders will work just find and I don't think you will find any of the loaders weak in any areas. You are all looking at them with a closed mind and not seeing the mounting kits as a whole. Any loader mfg Co worth spit does extensive and expensive testing to prove designs. All our loaders go through grueling strain gauge testing to find the weak areas and to make sure they will not break in the field. This is done with oversized cylinders and at pressures higher than what the tractor can put out. All so that we can know that you are getting a safe and quality product.
/ FEL Reinforcement #7
No. They are not any stronger in my opinion.
All the loaders with the tower straight down that I have seen have heavy framing in the center of the tractor and braces running from the center mainframe to the rear axle of the tractor.
/ FEL Reinforcement #8
Whichever you choose, don't forget the QA. :D
/ FEL Reinforcement #9
your right, dont pay attention to the design, they are all equal. btw. I hear kioti is having a blowout sale on used loader arms
/ FEL Reinforcement #10
then read the 2 years post about the Kioti 130 loaders...
All loaders are not created equal. keep reading Slackdaddy!
/ FEL Reinforcement #11
Hey! Is that a yellow card or what? Must be some sort of a foul for bringing facts into a discussion!
jb
Oh, forgot to point out that the gauge of the steel used also is an indication of the strength. Ask what the weight of the loader frame and mounts are. Heavier (for the same lifting capacity) is going to be more durable - generally. Then just let your experience and gut tell you if all that extra metal is a good thing or not.
/ FEL Reinforcement #12
Maybe true, though it appears Kioti has addressed it in a re-design. How those with the old design are being dealt with is another issue widely discussed in the Kioti forum.
KMW on the other hand, seems to be proven, as there are alot of them in the field and we have read of no issues.
/ FEL Reinforcement #13
I am not touching that with a ten foot pole. Glad I did not design or build that loader!
1999 CHEVROLET C7500 UTILITY TRUCK (A59910)
1999 CHEVROLET...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61567)
ABI 80-ASRT-074...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
JOHN DEERE 10' ROTARY MOWER (A62130)
JOHN DEERE 10'...
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
