Loader FEL Problem
/ FEL Problem #1
ronmueller
Datil New Mexico
Kubota MX51000 HST
The FEL on my Kubota MX51000 HST started acting up the other day. The FEL doesn't raise unless I lower the 3 point hitch all the way. I know I have a hydraulic leak somewhere on the FEL (I can smell the hydraulic oil) but haven't been able to find it yet. I also noticed the hydraulic oil was below the sight glass, so I added a bunch.
I suspect I may have air in the system. Anyone have a solution to my problem?
Thanks
Ron
/ FEL Problem #2
Air is the system will work itself out. Usually just raise and lower the loader and it will work out. Our skidder has air each time it is started in the morning. I just raise the grapples up and down a few times and then it is good to go. Make sure you didn't put too much oil. Just like the skidder, everything has to be a certain way for the fluid level to be correct. Sometimes the pump may "cavitate" if the level was too low, which means an air bubble is in the pump, so it doesn't pull fluid in or push it out. Could be a check valve on the lift that has a piece of trash in it that may be causing a problem. We had one that acted up, and an o-ring was the problem.
/ FEL Problem #3
If you have to lower 3 pt for loader to operate then it appears 3 pt valve isn't returning to neutral or leaking therefore robbing hyd oil from loader control valve. I think you need to keep a closer inspection of fluid level or the "HST may start acting up"
/ FEL Problem
Thanks ROUSTABOUT and Tx Jim. I should also add that the FEL will also raise if I tilt the buket either up or down at the same time. So it's just not tied in with the 3pt. I've tried cycling the FEL but it doesn't seem to help. So I guess air isn't the problem. Luckily the HST doesn't appear to be affected.
/ FEL Problem #5
If you have to operate bucket control circuit to get boom to operate then it sounds as if bucket circuit spool is leaking inside valve body. How many hrs are on machine?
/ FEL Problem #6
Try to disconnect and reconnect your FEL quick connects. I have seen lots of odd symptoms from partially seated connectors. I know it doesnt sound right but give it a try.
3 Propane Bottles (A65579)
3 Propane Bottles...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
(2) Rear Case 500 lb Wheel Weights (A66408)
(2) Rear Case 500...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
