Backhoe FEL position for backhoe work?
/ FEL position for backhoe work? #1
radair
White Mtns, NH
B3000HSDCC, U17 mini-ex.
I am determined to become a competent backhoe operator by the time the snow is gone and spring arrives. Consequently, I've been out regularly digging at snow/ice piles and moving them around. Here's my question:
The BX operators manual suggests lowering the loader bucket to give the bachkoe unit a "tripod" stance. They go on to say the bucket cutting edge should be lowered vertically into the ground surface where possible.
It seems like lowering the bucket cutting edge vertically puts more stress on the linkage (and bucket) than if you lower the bucket level with the ground. This seems particularly true when dragging the tractor around accidently, like an inexperienced operator may tend to do. /forums/images/graemlins/blush.gif
What do you guys do? Any other tips to share?
/ FEL position for backhoe work? #2
Watch an experienced operator. The outriggers are down lifting up both back wheels. The bucket is cutting edge down lifting up the front wheels.
Egon
/ FEL position for backhoe work? #3
Put the FEL curled into the ground. It helps BIG TIME! I do this on my BX22 so the BH does not move the tractor.
It is more stress on joints, connections etc but if it was designed correctly (which it is), it will be fine.
/ FEL position for backhoe work? #4
Placing your bucket cutting edge vertically helps to keep you from dragging yourself backwards as you use you backhoe . In time ,as you become more experienced with the hoe this will not be a major factor . You won't hurt the linkage , doing this .
Big Al
OK, it seems to be unanimous. It wasn't a concern to me when I was setting up on "soft" ground. Yesterday, on hard ice, I didn't like the way the bucket/linkage was getting stressed.
Thanks for the replies.
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59914)
2019 CHEVROLET...
PT 6' Dirt Pan (A64127)
PT 6' Dirt Pan...
2018 Bobcat MT85 (A64126)
2018 Bobcat MT85...
Femact 9 70REV Excavator Mulcher (A66285)
Femact 9 70REV...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2005 All Pro C7007 Trailer (A64126)
2005 All Pro C7007...
