FEL on John Deere 4500
/ FEL on John Deere 4500 #1
TRACTOR CRAZY
Massey Fergusson, Ford, John Deere, Allis
Heelo, I've got a JD 4500 with a front end loader that wont start, I want to tow it back to the barn how do I get the bucket up high enough to tow the tractor, will this cause ant damage to the hydraulics ?
/ FEL on John Deere 4500 #2
Welcome to TBN
With a helper holding the joystick back (like your raising the loader) jack it up or lift it with another tractor, then have the helper let go of the joystick and it should stay up.
/ FEL on John Deere 4500 #3
Or put the loader in "float" and pull it backwards.
/ FEL on John Deere 4500 #4
If the engine turns over you should be able to raise it at starter speed. Hold back on the stick and engage the starter. If it's anything like the loader on my 4310 it won't stay up for long so you will probably have to repeat.
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2006 MACK CV713 (A67714)
2006 MACK CV713...
PORTA POTTY (A68842)
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
CASE TV380 (A67714)
CASE TV380 (A67714)
2008 THE MACHINE CO. THAWZALL H250 HEATER  (INOPERABLE) (A68842)
2008 THE MACHINE...
