FEL hyd lines color code mix up ???
/ FEL hyd lines color code mix up ??? #1
gibby123
Nova Scotia, Canada
Kioti CK 25 HST
On my Kioti ( CK25HST with a 130 loader) the hydraulic lines "are" color coded.
The problem I am having is that the colors ( wire ties ) on the loader do not match up with the colors on the remotes. All 4 colors are the same but not in the same order. This is how it has been from new ( a dealer ) . The loader works fine , back is up ,front is down, right is dump and left is tilt ; from the stick all work great eaven, floating. Do I change the position of the lines or just the wire ties ?:confused:
/ FEL hyd lines color code mix up ??? #2
Interesting...
I would ask the dealer about this. It seems they are just in the wrong order..
But there could be more to it.. Something this simple is just too simple to be explained as someone put them on in the wrong order....
On my bota, I have color codes too and they match.
Later,
J
/ FEL hyd lines color code mix up ??? #3
If you change the hose positions then things will NOT will like they are supposed to...
3 Point Hitch Cultivator (A65579)
3 Point Hitch...
Linx EQ7018RS Trailer (A65640)
Linx EQ7018RS...
John Deere 350B Crawler Dozer (A65579)
John Deere 350B...
John Deere 3010 Tractor (A66408)
John Deere 3010...
Landhonor 11' x 19' Metal Carport (A66408)
Landhonor 11' x...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
