FEL hyd lines color code mix up ???
/ FEL hyd lines color code mix up ??? #1
gibby123
Nova Scotia, Canada
Kioti CK 25 HST
On my Kioti ( CK25HST with a 130 loader) the hydraulic lines "are" color coded.
The problem I am having is that the colors ( wire ties ) on the loader do not match up with the colors on the remotes. All 4 colors are the same but not in the same order. This is how it has been from new ( a dealer ) . The loader works fine , back is up ,front is down, right is dump and left is tilt ; from the stick all work great eaven, floating. Do I change the position of the lines or just the wire ties ?:confused:
/ FEL hyd lines color code mix up ??? #2
Interesting...
I would ask the dealer about this. It seems they are just in the wrong order..
But there could be more to it.. Something this simple is just too simple to be explained as someone put them on in the wrong order....
On my bota, I have color codes too and they match.
Later,
J
/ FEL hyd lines color code mix up ??? #3
If you change the hose positions then things will NOT will like they are supposed to...
Lincoln Electric Power Mig Welder (A65579)
Lincoln Electric...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2013 FORD F-150 (A65643)
2013 FORD F-150...
1999 MACK MIXER (A65643)
1999 MACK MIXER...
Metal Hog Feeder (A65640)
Metal Hog Feeder...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
