FEL Help
/ FEL Help #1
joshreed
I just got my 1510D back from getting the loader installed (Koyker 110) and I don't think the dealer mounted it correctly. When I put it all the way down, it is about 2-4 inches above the ground. I have to pivot the bucket downward to get it to touch the ground. Also when I bought the loader from him a couple weeks ago he said that everything worked great, but the ccontrol lever sticks pretty bad. My question to you guys is what if any liabitlity does the dealer have to make it right? I run a used car lot, and if I sold something and misrepresented it such as he has I would have to make it right, or buy the vehicle back by Kansas law, he is also in KS. Any suggestions on how to handle this will be greatly appriciated.
Thanks,
Josh
/ FEL Help #2
You should be able to lift the front of the tractor with the loader when the bucket is horizontal. I'd ask him to fix it before getting aggressive about his liability.
/ FEL Help #3
Thanks,
Josh
joystick or two lever control? Likely rusted. The 110 was discontinued perhaps a year ago, so he's got old stock, making it likely the valve body is old too. If two lever, two horizontal allen head screws where rubber boot meets valve body. Remove. In the now visible assembly are two connections/linkages with pins...these pins rust, causing the levers to hang up. Use a punch to drive the pins out, clean them up, grease them, replace, and fill the boot with grease to prevent further rusting. If that doesn't do it (and it always has), ask dealer to replace valve.
Never put one on a 1510, but all other apps the bucket, when flat, should rest on ground and still provide about 2-3" of lift.
/ FEL Help
I have asked him to fix it and he just says that it is on the only way it can go on.
/ FEL Help #6
I don't have the 4wd, but my Koyker 110 lowers just fine and lifts the front of my 1510 on level ground.
/ FEL Help #7
I don't know dink about Koykers or yanmars but if the FEL will not go flat to the ground in level position it is just about usless for moving loose dirt or gravel or even horse poop. Me thinks the dealer wrong.
/ FEL Help #8
I have a 1510 with a Japenese loader. Had some issues with it at first, but now that all is well I am happy. I can dig about 1 foot down with mine. It wouldn't do me any good if it not only wouldn't lower to the ground but couldn't lift the tractor. I have found it convenient for popping small trees up by the roots. That dealer did something wrong and doesn't want to fix it for you.
/ FEL Help #9
I agree completely!!! I have YM1700 with a Great Bend loader I installed myself. With the bucket flat it will lift the front fires about a foot off the ground.
I think I would be looking the installing dealer straight in the eye and tell him to fix it.
/ FEL Help #10
Josh,
After installing a few loaders it becomes necessary to make a few adjustments during the initial setup.
It sounds as though your dealer-installer has the front loader arms attached too low on the bucket. This allows for maximum lift but insufficient down pressure and bucket height is not low enough. I can think of only two options to make your FEL work normally: Cut off and reposition the front loader arm mounts at the bucket, or remove 3" from the vertical towers. Both require cutting and welding....not too complicated if your equipped to make the changes.
I think if you present a solution to your installer, he may not like it but have no room for an argument and should make the repairs.
If you could supply us with a few pictures of the loader at it's lowest and highest points it might show us if there is another alternative. Good luck.
Mark
/ FEL Help #11
Are you sure that the loader frame is not hitting the bumper when lowered? I have installed over a dozen loaders on the YM1510 (all Koyker 80s though) and most of them required the bumper to be cut off, moved back about 2" and then welded back on. If this was not done the loader would hit the bumper and not go all of the way down. I dont know if this is an issue on the 110 or not. Might be worth checking out.
Just checked the 110 instructions for the 1510 and it does require the bumper to be moved so that the bucket does not it.
Aaron
Parts@hoyeTractor.com
(940)592-0181
/ FEL Help
Aaron
(940)592-0181
That is exactly what is happening! I showed them the install instructions from your site (thats where I get my parts) and the installer asked me to bring it back in to be corrected. They didn't install the belly brackets correctly either, they are not as low as the ones in your pictures, but hopefully they will get it fixed. I really appriciate everyones help in this.
/ FEL Help #13
Josh you should have got a manual with the loader, in it should be the phone
number of Koyker. Give them a call and talk to an engineer. I installed my own
Koyker 110 a couple of years ago on a 1610d. After I got done I couldn't get the loader to connect up. I figured that I would have to do some cutting and
welding to make it fit, after a chat with the factory guy I had it on and all is
well.
If your dealer followed instructions as provided by Koyker your loader should
fit and be able to lift the front wheels off the ground.
Gary
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
FOUR RACKS OF MISC FILTERS (A67714)
FOUR RACKS OF MISC...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
PALLET WITH 3 ELECTRIC CHAIN HOISTS AND ONE MANUAL CHAIN FALL OUTBOARD MERCURY PARTS MOTOR (A66738)
PALLET WITH 3...
