FEL Hard Lines
/ FEL Hard Lines #1
1m21
Dundee, NY
YM2000BD
Anyone find a good source for steel hydraulic tubing?
I need to make new hard lines for a FEL.
Thanks.
/ FEL Hard Lines #2
McMaster Carr not cheap but well specified and available
/ FEL Hard Lines #3
Most htdraulic hose shops have it in 10ft lengths. Harbor freight has a tubing bender for about $30. The problem is, how are you going to keep it from rusting?:eek:
/ FEL Hard Lines
I have thought about the rust problem (being I'm in upstate NY). Good paint or if they will fit in my oven, I could powder coat them after they are bent. There is always stainless steel tubing also.
/ FEL Hard Lines
What PSI rating do I need on the tubing. The hydralics are set at about 2000 PSI but how much over that do I need to cover the shock load?
/ FEL Hard Lines #6
You want .049 wall thickness, also seamless. Call around to any good hydraulic shop. They should have in stock. I hope you have a good bender and flaring tool, this is not like brake line. And as far as stainless, avoid it. It is very hard and brittle, difficult to work with. I make steel lines and have never had a rusting problem with good quality hydraulic tubing. You can paint it if you like.
/ FEL Hard Lines #7
I have had good luck with rigid steel tubing from McMaster Carr and after I got tired of flaring it I tried flareless fittings from Discount Hydraulic Hose. I used both the "flareless compression" fittings and the "JIC Convert-A-Flare" fittings. Neither type of fitting looks very substantial, but they have held up several years with no leaks, so they must be okay. The "JIC Convert-A-Flare" fittings are most useful because they work with standard JIC male flares, whereas the flareless compression fittings adapt to a pipe thread which you then have to adapt to your particular situation. I am not getting rid of my flaring tool just in case these things start leaking, but if you do not have a flaring tool I would try the flareless fittings before buying one (the good flaring tools are expensive).
/ FEL Hard Lines #8
I used the two-ferrule mechanical grip design from Swagelok when I designed and built my loader this summer. I also welded some of my fittings. I welded the fitting on the cylinder connected to the hose. I used 3/8" tubing because I got free and it was an inconel material with nickel base that does not rust. I made it out of the scrap pieces.
/ FEL Hard Lines #10
Who's tubing did you use? I need to do the same thing, the hard tube on my loader is long gone, as in not there, I don't like all the long rubber lines. Yours looks great! And where did you get the Swaglock (spelling) fittings. Last dumb question, what is Iconel material?
Thanks,
Bill
/ FEL Hard Lines #11
I was able to get my tubing from work as scrap pieces. Inconel tubinng is used for high temperature over 1800 deg. with high pressure without any problem.
You can use stainless steel tubing as it will bend without any problem but the cost is higher than steel tubing. You can order from McMaster Carr tubing and compresssion fittings.
  • Comp. Tube fittings.pdf
/ FEL Hard Lines #12
I forgot to add a note about the tubing sizes printed on the top of the page from McMaster Carr.
/ FEL Hard Lines #13
Swedglok fittings are REALLY expensive.
/ FEL Hard Lines #14
Over here in Holland, you can get these pipes at allmost every corner of the street, at agricultural dealerships.
If you want them cheaper, in a nearby city there are at least 4 major industrial retailers that can supply for better prices.
I dont know about the availability of these items where you live, but if i need a special hydraulic part at the company i work, i use the internet to look for phone numbers and just call.
Usually i find the items 50% cheaper within a half an hour.
Dont email, just phone so you are in direct conversation with them.
1  JACK (A66091)
1 JACK (A66091)
2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2006 CASE 430 SKID STEER (A65056)
2006 CASE 430 SKID...
2015 Ford F-750 Party Shuttle Bus (A66736)
2015 Ford F-750...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
