FEL Hard Lines
/ FEL Hard Lines #11
I was able to get my tubing from work as scrap pieces. Inconel tubinng is used for high temperature over 1800 deg. with high pressure without any problem.
You can use stainless steel tubing as it will bend without any problem but the cost is higher than steel tubing. You can order from McMaster Carr tubing and compresssion fittings.
  • Comp. Tube fittings.pdf
/ FEL Hard Lines #12
I forgot to add a note about the tubing sizes printed on the top of the page from McMaster Carr.
/ FEL Hard Lines #13
Swedglok fittings are REALLY expensive.
/ FEL Hard Lines #14
Over here in Holland, you can get these pipes at allmost every corner of the street, at agricultural dealerships.
If you want them cheaper, in a nearby city there are at least 4 major industrial retailers that can supply for better prices.
I dont know about the availability of these items where you live, but if i need a special hydraulic part at the company i work, i use the internet to look for phone numbers and just call.
Usually i find the items 50% cheaper within a half an hour.
Dont email, just phone so you are in direct conversation with them.
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
Dual Rear Wheel Axle (A59230)
Dual Rear Wheel...
16ft. Canoe w/ 12ft. Continental Trailer (A59231)
16ft. Canoe w/...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
