FEl Grease Zerks
/ FEl Grease Zerks #1
Turfman
South Weber Utah
Kubota B2710
Lubing the FEL on my B2710 yesterday and I noted two things: 1) The zerks were loose in their threads, so loose that I could turn them with the grease gun. I tightened them.
2) One of the zerks had paint on the opening and wouldn't take any grease. The dealer had greased it, as evidenced by the grease on the fitting, but none had gotten into the bearing area. I cleaned the paint off and it took several pumps to get grease out the edges of the bearing.
Only had about 14 hours on her, hope I didn't damage it by running it without grease.
/ FEl Grease Zerks #2
Do not fear. All will be ok. You may find that some of the zerks will wear or get plugged by dirt and have to be replaced on a regular basis. I have had to move some around when greasing and had no spares.
Egon
/ FEl Grease Zerks #3
I am fast approaching my 10 hour first grease and was worried about some of the zerks. Question is what kind of grease are you alll using ??? There was another thread where they adviced using any type, but this being my first front end loader I wanted to be careful.
Thanks.
/ FEl Grease Zerks #5
I use a heavy Molybdenum, high temperature, high pressure grease.
If you do a lot of digging monitor the lower bucket joints. They tend to get full of dirt long before the other joints. I clean and grease them twice as often.
/ FEl Grease Zerks #6
Looks like the same as my loader - one of the grease fittings has paint on it; can't get grease in. This is a dumb question, but how do you get the paint off? Paint thinner? Its orange paint..
Do you always put enough grease in so that you can see the old grease coming out? Do all the fittings let you see the old grease coming out? I'm thinking that every five hours is too much, except that the rear wheel on the bush hog wouldn't swivel after four or five hours of work and I had to grease it to get it to swivel. On that fitting I can see the old grease coming out on the second squirt of the grease gun.
Pete
/ FEl Grease Zerks #7
To get the paint off mine, I took a small screwdriver and just lightly scraped it off. The paint wasn't really stuck to the metal so it came off in a small flake.
/ FEl Grease Zerks
<font color=blue>This is a dumb question, but how do you get the paint off? </font color=blue>
I just scraped it off with my Leatherman. Tapped it twice to crack the paint and scraped it off with the blade.
<font color=blue>Do you always put enough grease in so that you can see the old grease coming out?</font color=blue>
Yes, I just keep pumping until I get a LITTLE bit coming out the edge.
/ FEl Grease Zerks #9
My loader manual says to use a high quality grease designating "extreme pressure" and containing Molybdenum disulfide. The manual also said that the label might specify "Moly EP".
Seems to me that the price difference was about $1.00 more for the EP as opposed to the general purpose grease. At 2-3 greasings per cartridge that seems like real cheap insurance on keeping the wear down on the bearing surfaces.
Just my opinion though,
Don
/ FEl Grease Zerks #10
I just bought a couple of tubes of Moly graphite--haven't used them yet. Anybody have any experience/opinion on this grease (It is marked as extreme pressure as well). I figured the graphite might coat the surface a little better./w3tcompact/icons/wink.gif
/ FEl Grease Zerks #11
Where did you buy your grease gun and the moly grease? Who has the best prices? /w3tcompact/icons/smile.gif
/ FEl Grease Zerks #12
Should I not use Walmart grease?
-T
/ FEl Grease Zerks #13
My opinion is that there are probably only a few manufacturers of all of the brands out there. I would guess that WalMart uses one of the major oil companies to supply the grease with the WalMart label on it.
My best guess would be that as long as the specifications are the same there would be no problem. I think that the main thing is the frequency of the greasing. By putting in new grease you drive out the metal dirt and moisture that has accumulated in the bearing areas.
I personally grease untill I see the grease come out without any discoloration, then I opperate the FEL and give each zerk another couple of shots. It is also a good idea to wipe the zerks off before greasing so that no dirt gets pushed into the area that you are greasing.
Don
/ FEl Grease Zerks #14
I purchased a couple tubes of extreme pressure grease from Pep Boys. I purchased a new grease gun from nothern tool. (It was cheaper than pep boys even with shipping.)
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
generator trailer (A61569)
generator trailer...
2018 Nissan Versa Sedan (A61574)
2018 Nissan Versa...
