FEL float postion. FEL removal.
/ FEL float postion. FEL removal. #1
MDM
Platinum Member
East Ohio
Kubota L2800HST
I just bougt a L2800 HST. I've been reading the manual on the loader. How do I get it to go to the float position? In the manual, the joystick is all the way forward, but when I do that, it just lifts the tractor off the ground.
Also, anyone have any pointers on FEL loader removal. I'm going to follow the manual, but I thought you guys might have some tricks up your sleeves.
Its the LA463.
Thanks.
/ FEL float postion. FEL removal. #2
I had the same experience with the float position... all the way forward just keeps lifting... until you push it even farther forward - like - you are gonna break it... it will "pop" or click into the float position. The regular movements are in the square pattern - float is like a click up in the middle of the top of the square.
Can't help with the FEL removal - I'm guessing - the BX24 loader is different enough that I would confuse you!
Ok. I found the float position.
/ FEL float postion. FEL removal. #4
I sometimes bump the hydro pedal forward or back(lightly) or raise the loader up and down a little to try and settle it into place.
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
(2) UNUSED 12-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12-16.5...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
NEW HOLLAND 6' SICKLE BAR MOWER (A64280)
NEW HOLLAND 6'...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
Caterpillar T Series Lift Truck Service Manual (A63117)
Caterpillar T...
