FEL Cutting Edge
/ FEL Cutting Edge #1
arnoldziffel
Branson 4225h, Mahindra 2516, several Toro Wheel Horse 522xi machines.
I have a new Branson 4225h. I'm just starting to use it and believe it would be wise to install a FEL cutting edge.
I want a good quality cutting edge. I've not yet spoken with my dealer about this.
- Does Branson sell cutting edges specific to their line of tractors? If yes, any experience or opinions on quality and pricing?
- Are good or better cutting edges available from other sources in the marketplace?
Thanks.
/ FEL Cutting Edge #2
I put a Pihrana tooth bar from BXpanded on mine. It works well for my use.
/ FEL Cutting Edge #3
My Branson dealer didn't have any specific cutting edges for my 8050 and I didn't get one ordered soon enough for it.
That said mine doesn't have the standard bolt pattern for most cutting edges and with 6-700 hours on it I still need to add one,
I have had to tweak mine back a bit straighter a couple of times.
The easiest to add will be the various weld on cutting edges, I prefer a straight edge over the toothed style edges.
/ FEL Cutting Edge #4
I have an eight tooth - tooth bar from a company called Rankin. It does what I need. I think your best bet - Google - tooth bar and stand back. There are probably hundreds of companies that make all forms of add-on tooth bars. If you look closely - thru the grass & weeds - it's yellow, it's bolted on the lip of the bucket - it has eight large hardened teeth.
/ FEL Cutting Edge
Thanks for the responses so far.
I should have mentioned in my first post that I foresee using the FEL primarily for infrequent snow management and very infrequent sand and run-a-crush movement.
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
2006 Peterbilt 387 Semi (A64047)
2006 Peterbilt 387...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
2014 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61568)
2014 Chevrolet...
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
CATERPILLAR GC25K STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR GC25K...
