FEL bypassing
/ FEL bypassing #1
Notforhire
Southwestern Virginia
Kubota L47TLB
I have a Kubota 3240 W/ 724 loader. It has about 15 hrs. on it. I needed to lift a Zero Turn mower. The mower weighs around 1100#. I was lifting it with chains attached to the bucket. I couldn't lift the mower at all. The Hyd just bypassed. I removed the bucket and repeated the lift. I was able to rase the mower a couple of feet, but that was about it.
The loader spec. sheet says that the lift cap. @500mm forward and max hight is 1415 lbs. At the pivot pins an 1500mm ht it goes up to 2324 lbs.
I would like to check the Hyd relief setting. Can I do this by plugging a pressure gauge into my rear remote, or do I need to connect to the loader valve?
Thanks, Bill
/ FEL bypassing #2
Connect it to the IN port of the loader valve or one of the cyl QD's
The 3pt has it's own relief.
/ FEL bypassing #4
This may be a dumb question, but isn't it the case that the lift capacity is highest at max height because the bucket/load is closer to the tractor, and lift capacity drops as the arms go down to horizontal?
/ FEL bypassing
Now if it was a dumb question, I would have the answer. :scratchchin:
Honestly, I don't know. Being non metric I don't know how high 1500mm is. Maybe someone smart knows the answer.:anyone:
The spec sheet had several other lift cap. data at different heights ect. I just gave what was the min. and max. lift cap. on the sheet.
My reasoning was that without a bucket installed, the FEL should handle a 1100# mower, at any lift hight. This is why I suspect that the bypass may be set too low.
I thought a friend of mine had a gauge setup, but he doesn't. I'll just have to load it up and bring it to Kubota and get it checked.
Bill
/ FEL bypassing
Well I finally got around to bringing the tractor to Kubota. They said that the relief was set 50# below max, and that they will adjust it. Unfortunately they didn't have the correct shims. I left the tractor there. It should be ready on Wed.
Will 50# increase make that much difference in the lift cap.?
/ FEL bypassing #7
About 250 lbs increase per cyl, x 2 =500 lbs increase at the cyl with a straight on push. The angle of the cyl to the mounting point will probably be less.
You could have made yourself a hyd test set for about $30.
/ FEL bypassing
Thank you for the info. I thought about getting a test set, and I may yet.
I was pretty sure that it was bypassing early. The tractor is new, and I thought it best for Kubota to make any adjustments needed. (He who touched it last owns it, rule.)
If you are correct, and I have no doubt that you are, the additional lift will put the loader in the advertised lift range.
Thanks, Bill
/ FEL bypassing #10
It's the opposite. As the loader raises the loader cylinder's leverage chances for the worst. The higher you go the lower your lift capacity. The most will be at ground level.
My 640 SL loader will lift 4856lbs at ground level, 4008lbs at 1.5m (59"), and 3440lbs at maximum height.
/ FEL bypassing #11
Click on the link in post #9 and look at the loader specs.
The angle on the cyl is changing also.
/ FEL bypassing
This is from the Kubota 3240 brochure.
Just noticed this; In the brochure it says that the specs. were taken from a L3540 @ 2560psi, and a L3940 @ 2630psi. When I look in my OM, system pressure is the same for these three models and listed as 2567 lbs for L3240, L3940 and L4240. I don't get it???
JJ I'm not sure what you want me to see in the spec. Please explain.:newhere:
Bill
/ FEL bypassing #13
The weight you can lift down low, is greater that the weight at max lift height.
That means that you sometimes can lift something, but not be able to lift it high.
The closer your lift point to the pins, the more weight you can lift.
You can lift more using a chain over the back of the bucket than the lip of the bucket.
/ FEL bypassing
I see. That is exactly what happened. I was able to lift about two feet then it just bypassed. Had I been able to shorten the chain the lift would have been lower, and would have had more power. Makes sense. Thank you.
Bill
/ FEL bypassing #15
Bill
I think the main reason they are telling you what tractor the specs are taken form in because of the lift height, the bigger tractors will lift higher.
/ FEL bypassing
I get that, it's the pressure difference that seems weird. The brochure lists different pressure for the different models. According to the OM they should be 2567 lbs.
JOHN DEERE 5403 TRACTOR (A64280)
JOHN DEERE 5403...
Adams 16T Tender Body (A63688)
Adams 16T Tender...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2006 Shamrock 10ft. S/A Enlcosed K-9 Transport Trailer (A61574)
2006 Shamrock...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
